Oil consumption
Old Sep 9, 2007 | 05:05 PM
96lude_srv's Avatar
Default Oil consumption
98 gs-r with 120 000km. The car is burning alot of oil under heavy acceleration, like i can go through half a litre in 2 days, but if i don't vtec oil consumption is fine. I've checked the tail pipe everytime i kick it, no blue or black smoke come out at all. I look under the oil pan, seem to be a bit of oil hanging on the drain bolt, but its not like dripping hard or anything. When i replaced the spark plugs, i notice there was fresh clean oil on one of spark plug in one cyclinder. THe car is fully tuned up. Could it be a bad seal??
Old Sep 9, 2007 | 07:16 PM
LastDetail's Avatar
Default Re: Oil consumption (96lude_srv)
I would say that your rings are going bad. Do a compression check
Old Sep 9, 2007 | 08:03 PM
deegz's Avatar
yes it could be your valve guide seals. We changed my little sisters and it solved the problem.
you could do a compression check, but its kind of odd that its just one.
if you do a compression check on all your slugs, and its all low and relatively close, then its your rings....but it sounds like a seal to me.
Ohbebe75
Aug 4, 2010 06:29 AM
Powelly
12
Sep 5, 2008 09:54 AM
peel17
Feb 1, 2005 11:28 AM
Layziebtnh055
Jun 22, 2004 03:25 PM
Nextelbuddy
Oct 1, 2003 08:17 PM
