problem after cluth fluid flush
Old Sep 7, 2007 | 02:21 PM
sickofitall1113's Avatar
Default problem after cluth fluid flush
ok so after i got the fluid as clear as i could ( the resevoir is still very very cloudy but better than before) i tightened everything back up and put the cover on. i got in the car and it took forever to get the pressure back. it did come back. but everytime i stop the car and get back in, i need to pump it a whole bunch of times before it gets back to the way it should do. i came outside this morning and it actually went all the way to the floor pretty much by itself. i thinki i did all the steps correctly but could this be an air bubble or pressure issue within the system? anyone have any ideas?
Old Sep 7, 2007 | 03:07 PM
silverEG6's Avatar
make sure all lines arent kinked to where it leaks.. and re bleed to make sure all air is out... make sure to check your slave cylinder and make sure the inner seal is not busted..
Old Sep 7, 2007 | 03:09 PM
its not leaking though, the level is the same as when i put the new fluid in. the pedal just goes down to the floor after a short period of not using it
Old Sep 7, 2007 | 03:28 PM
jdmboostfed's Avatar
Has your clutch slave or master cylinder ever been changed?
Old Sep 7, 2007 | 03:52 PM
uh no. but llisten, this happened the SECOND, the instant i tried the clutch again after i changed the fluid. there is no doubt in my mind it was to do with air in the system or something like that. would air make it do that? i should bleed it again maybe?
Old Sep 7, 2007 | 03:55 PM
nA_Gsr303's Avatar
Default Re: (sickofitall1113)
errrr..... yes
Old Sep 7, 2007 | 04:56 PM
hahaha alright. is there any way to ensure that air does not get in the system tomorrow when i bleed it again?
JoshV1288
19
Jan 26, 2013 02:41 AM
DanielSLe
Dec 11, 2010 07:42 AM
autoxthis
Aug 21, 2008 08:23 PM
Tegraracer90
Mar 10, 2008 12:55 PM
