need help asap
Old Sep 10, 2007 | 10:04 PM
acura0113's Avatar
Default need help asap
i put a new head on my 93 integra and everything went smooth , i put the timing belt back on , now when i start it i revs to about 4 grand and it and theres a loud tapping like someone hittin the valve cover with a hammer , so i took the belt back off and tightened up the tensioner up more and started it back up and now i still have the same prob ... if anyone could help id greatly appreciate it ....
Old Sep 10, 2007 | 10:25 PM
St Jimmy's Avatar
* B A N N E D *
Default Re: need help asap (acura0113)
Are you sure you lined up all the marks right? The marks on the cams and the TDC mark on the crank pulley?
Old Sep 11, 2007 | 09:26 PM
acura0113's Avatar
Default Re: need help asap (St Jimmy)
yeah thats what my friend josh told me to do , but the motor didnt do it before i took the other head off , do you think it might be a bad head ...
Old Sep 11, 2007 | 09:37 PM
Mfoehrkolb's Avatar
vould be some valve train problems. if yoru timming is off, it def isnt good.
Old Sep 13, 2007 | 10:13 PM
acura0113's Avatar
Default Re: (Mfoehrkolb)
well i got another bored head you think i should just go ahead and put it on ... cuz i just bought it brand new i kno its good lol
Old Sep 13, 2007 | 10:18 PM
db1_jdm's Avatar
Default Re: (acura0113)
do a valve adjustement! it should take care of that...make sure all the cam bolts in the head were torqued correctly and in the correct sequence!
Old Sep 13, 2007 | 11:37 PM
St Jimmy's Avatar
* B A N N E D *
still think your timing is off, you sure you checked it?
B1900D
Feb 8, 2014 02:59 PM
ericnnz23
14
Mar 9, 2013 04:33 PM
hondateg10
May 3, 2008 08:16 PM
kornerk12
Dec 7, 2006 04:14 PM
Muckman
Jun 19, 2003 07:42 AM
