Just replace my VSS.
Months ago I noticed that my speedometer is not reading correctly base on my rpm. Then today I finally replaced my VSS (base on research I did here) and still my speedometer is still off by at least 15mph (again this is base on my rpm). What do you think guys the problem? What else to check? I feel like I wasted my $150 for nothing. please help.
Modified by civic91 at 8:48 AM 9/10/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2daturbo »</TD></TR><TR><TD CLASS="quote">what year car, what transmission and what size tires are on the car...let me know and ill get back to you with some ideas...</TD></TR></TABLE>
It a 1995 GSR, tire is stock size.
Tire size will not affect the indicated speed in the cluster.
To the OP, have you verified that the tachometer is correct? Have the gauge needle been removed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">
To the OP, have you verified that the tachometer is correct? Have the gauge needle been removed?</TD></TR></TABLE>
Never touch the needle. This morning on the way to work, my rpm is around 2.5k (5th gear) and my speed is still 20mph. The speedometer needle is moving very slowly.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator »</TD></TR><TR><TD CLASS="quote">You have a 91? Have you checked the cable connection in the cluster?</TD></TR></TABLE>
I have a 1995 GSR. No, I haven't check the cable connection in the cluster. How do I check the cable in my cluster?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic91 »</TD></TR><TR><TD CLASS="quote">
I have a 1995 GSR. No, I haven't check the cable connection in the cluster. How do I check the cable in my cluster? </TD></TR></TABLE>
You do not have a speedometer cable in a 1995 GSR. From your SN, I thought that you had a 91.
If you have another cluster, swap it to check the gauge operation.
If you have another cluster, swap it to check the gauge operation.</TD></TR></TABLE>
Is there any other way to check the gauge operation since I don't have another cluster!
check the pins in the connector my friend has a similar problem.. the terminals had corrodid away and had a bad connection.. with a new connector problem was solved!
I know this is an old thread but I had to correct something for anyone reading this.
Actually, that's not true. If you change the stock diameter of the rim+tire, the speedometer won't reflect the correct speed.
jerm001
12
Apr 2, 2006 03:20 PM
aandrewcc
Mar 30, 2006 09:32 AM
