Clutch Problem...Please help
Old Sep 11, 2007 | 08:25 AM
krazykay5487's Avatar
Default Clutch Problem...Please help
I installed a new Exedy stage 2 clutch and flywheel this weekend. Everything went fine while installing it, no problems. When I finished I took it around the block and the car bogged badly everytime i shifted, when engaging the clutch in every gear 1-2-3 it seems like you need to give it A LOT of gas. Anyone know what I need to do???
Old Sep 11, 2007 | 09:07 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: Clutch Problem...Please help (krazykay5487)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazykay5487 &raquo;</TD></TR><TR><TD CLASS="quote">I installed a new Exedy stage 2 clutch and flywheel this weekend. Everything went fine while installing it, no problems. When I finished I took it around the block and the car bogged badly everytime i shifted, when engaging the clutch in every gear 1-2-3 it seems like you need to give it A LOT of gas. Anyone know what I need to do???</TD></TR></TABLE>
bleed system?
check bearing?
master?
slave?
disc fit on splines ok?
straps on side of plate broken?
disc backwards?
Old Sep 12, 2007 | 12:00 PM
I have double checked everything. Then I took the car out for another drive, I notice at high speeds everything is ok, the clutch is fine no slipping, goes in gear fine, there is pressuer on the pedal, the only problem is shifts at low speeds and low RPMs the whole car shakes, its not normal(i know how to drive stick). In 1st you have to rev it up to about 2500-3500 RPMs, to get it smooth and in every other gear you need to shift after 4500 RPMs. Has anyone experianced something like this? Should I just drive then car and break in the clutch and see what happends?
Old Sep 14, 2007 | 01:20 PM
Anyone?
Old Sep 14, 2007 | 01:44 PM
B1uNight's Avatar
It's your new lighter flywheel. With a lighter flywheel, revs drops faster and you need to keep the RPM high for the clutch to engage smoothly. It's about inertia.
Read this:
http://www.team-integra.net/fo...Topic
m0823
Sep 17, 2010 04:21 PM
itslogz
Mar 17, 2008 03:56 AM
Wheelman-CZ
Sep 4, 2006 10:56 PM
Chiller
Apr 10, 2005 10:52 PM
FLCivic
15
May 31, 2004 09:22 AM
