THROTTLE CABLE PROBLEMS
Old Mar 16, 2008 | 06:15 PM
ateggy1's Avatar
Default THROTTLE CABLE PROBLEMS
I GOT A 94 INTEGRA LS, AND I DID THE SWAP TO A GSR, BUT I CHANGE THE THROTTLE CABLE AND TRY TO PUT IT BACK ON, BUT IT SEEM THAT IS LONGER!! IS LOOSE FROM PEDAL, AND THROTTLE BODY ANY IDEAS???
Old Mar 17, 2008 | 05:24 AM
matmcg's Avatar
tighten it
Old Mar 17, 2008 | 07:34 AM
crazyguy's Avatar
Default Re: (matmcg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by matmcg &raquo;</TD></TR><TR><TD CLASS="quote">tighten it</TD></TR></TABLE>
it wont work. because LS throttle cable is longer than GSR, u will need to get a GSR throttle cable.
Old Mar 17, 2008 | 09:13 AM
ateggy1's Avatar
Default Re: (crazyguy)
YEA THATS WHY I TOOK THE LS CABLE, AND PUT ON THE GSR CABLE AND ITS TIGHT AND EVERYTHING, BUT ITS LOOSE FROM PEDAL
Old Mar 17, 2008 | 09:30 AM
pokmijn's Avatar
Default Re: (ateggy1)
when we did that swap couple day ago that happen to us too what you have to do is swap everything that holds the gsr trottle cable over then it should work cause thats what we did but ill ask my bro to make sure when he gets home.
Old Mar 17, 2008 | 10:31 AM
iH8RICERZ's Avatar
Default Re: (pokmijn)
The gsr and ls throttle body pulleys are different.....Try swapping the pulley and see if that helps any at all.
Old Mar 17, 2008 | 12:53 PM
ateggy1's Avatar
Default Re: (iH8RICERZ)
koo ill try that thanx guys...
Old Mar 17, 2008 | 09:27 PM
dcRay's Avatar
I reused my ls cable work with my gsr engine swap. I trimmed the end off and use aftermarket cable lock. Work flawless.
g0tgot
Oct 11, 2008 07:50 AM
slowB20ej8
Mar 27, 2008 12:23 PM
123Four
Sep 12, 2007 03:08 PM
lsvtecboi'95
Aug 4, 2007 07:53 PM
mrbsponge
11
Feb 3, 2004 04:03 PM
