Power Steering Fluid is leaking
My power steering fluid is leaking but i cant figure out why or where exactly the leak is coming from. I noticed that one of the small hoses has some fluid from the leak but i see no signs of wear on the hose or any sort of crack in the p.s. reservoir tank. I also noticed that the reservoir was under the minimum mark so i just filled it to the top to see if that helps at all. I have NO idea why it's leaking so can someone please help me out. I rather try to figure it out myself (or with your guys/gals help) than take to the dealer to see whats wrong with it. Does the small black ring that holds the hose onto the reservoir tank have anything to do with it? Thanks in advance!
EDIT: I own a 2000 Acura Integra LS if that matters.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AcuraTilIDie »</TD></TR><TR><TD CLASS="quote">My power steering fluid is leaking but i cant figure out why or where exactly the leak is coming from. I noticed that one of the small hoses has some fluid from the leak but i see no signs of wear on the hose or any sort of crack in the p.s. reservoir tank. I also noticed that the reservoir was under the minimum mark so i just filled it to the top to see if that helps at all. I have NO idea why it's leaking so can someone please help me out. I rather try to figure it out myself (or with your guys/gals help) than take to the dealer to see whats wrong with it. Does the small black ring that holds the hose onto the reservoir tank have anything to do with it? Thanks in advance!
EDIT: I own a 2000 Acura Integra LS if that matters.</TD></TR></TABLE>
maybe the motor from the power steering
It hasn't leaked since i filled it back up so idk whats up with it. I gotta find some time to really check it out.
94c1v1cex
May 21, 2007 05:03 PM
