antenna not functioning
Old Mar 12, 2008 | 04:31 PM
GSR1hits's Avatar
Default antenna not functioning
my lil brother pulled the antenna up while the car was off and now it wont go down at all do you think the motor is [freak]ed up now or its the antenna itself??
Old Mar 12, 2008 | 04:32 PM
GSR1hits's Avatar
Default Re: antenna not functioning (GSR1hits)
didnt know i couldnt use foul language sorry!!
Old Mar 12, 2008 | 04:38 PM
BlueIntegraBoy's Avatar
Push the antenna back down. The Integra antennas are known to go out. There are alternatives to having the stock antenna.
Old Mar 12, 2008 | 06:50 PM
GSR1hits's Avatar
I TRIED BUT IT WONT GO DOWN WITHOUT EXCESSIVE FORCE AND I DONT WANT TO MESS IT UP MORE THEN IT IS ALEADY
Old Mar 12, 2008 | 06:53 PM
Default Re: (GSR1hits)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR1hits &raquo;</TD></TR><TR><TD CLASS="quote">I TRIED BUT IT WONT GO DOWN WITHOUT EXCESSIVE FORCE AND I DONT WANT TO MESS IT UP MORE THEN IT IS ALEADY </TD></TR></TABLE>
I think it's too late
Old Mar 12, 2008 | 08:43 PM
Rikter's Avatar
The anteanna cable itself has nylon teeth in it. I'm willing to bet when your brother pulled it out he stripped those teeth.
Your best bet it to take the whole antennea out and check the white nylon cable. See if the teeth are intact. If they aren't..... I bet they're still in the motor and that's not good.
-RIk
Old Mar 12, 2008 | 09:53 PM
theaznracer's Avatar
Default Re: (BlueIntegraBoy)
if so...
take it out and get a s2k antenna
some mofication required but not too much should take
about 20-30 mins max to install
btw imo it looks a lot better
compared to stock
Old Mar 13, 2008 | 02:01 AM
DVSBIZZYB's Avatar
When you turn on and off you stereo can you hear the antenna motor? If you can hear it the motor it is still good. You just have to replace the antenna with a good cable.
Old Mar 15, 2008 | 11:07 PM
GSR1hits's Avatar
REPLACE IT WITH AN S2K ANTTENNA .. WHY THE ANTENNA OFF THAT? IS IT MUCH DIFFERENT ?
Old Mar 15, 2008 | 11:58 PM
if its not working.. and its the motor
might as well.. its cheaper and looks better imo
Old Mar 16, 2008 | 05:42 AM
Dogginator's Avatar
Daisy... Daisy...
People have had reception problems with the S2000 antenna.
https://honda-tech.com/zerothread?id=1540513
I am currently seeking an amplified internal on-the-glass antenna and will then just get an antenna delete plug. Any suggestions?
bboyoracle
Jul 3, 2006 10:37 AM
hondaracing1
May 12, 2005 05:37 PM
ng
Dec 19, 2003 07:15 PM
shatshadarach
Sep 9, 2003 04:06 AM
Ben-VTEC
Feb 28, 2003 10:55 PM
