Axles difference DA vs. DC
Old Mar 14, 2008 | 09:36 PM
ricecooker415's Avatar
Default Axles difference DA vs. DC
i understand the difference in the driver side. my question is more specific. i need to know is there a difference in the length for the passenger side. whats the difference between a 90-93 integra and a 94-01 integra passenger axle?
Old Mar 14, 2008 | 10:34 PM
g2daturbo's Avatar
Default Re: Axles difference DA vs. DC (ricecooker415)
passanger side axles are exactly the same... i have used them many times and if you do a search for each one and compair part numbers you will come up with the same numbers i am currrently running a 94 integra axle in my 91 da... Good luck!
Old Mar 14, 2008 | 11:15 PM
man03globe's Avatar
doesnt abs matter in a situation like this, i know this is a question answerin a question but couldnt help but mention it
Old Mar 15, 2008 | 02:16 AM
crazyguy's Avatar
Default Re: Axles difference DA vs. DC (man03globe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by man03globe &raquo;</TD></TR><TR><TD CLASS="quote">doesnt abs matter in a situation like this, i know this is a question answerin a question but couldnt help but mention it</TD></TR></TABLE>
abs and non abs axles have the same length, non abs cars can run abs axles. abs axles cost more $$ than non abs axles.
Old Mar 15, 2008 | 09:16 AM
abs axles has a speed ring on it so it can pick up the speed of that wheel. other then that, their exactly the same. ever since i swap my axles with oem dc2 ones, i seem to have a binding noise on that side.
Old Mar 15, 2008 | 05:51 PM
man03globe's Avatar
Default Re: (ricecooker415)
nice 2 know sumthin like that, but other than d noise evrythin is kool right?
Old Mar 16, 2008 | 12:20 AM
umm. i suppose. unless it a balljoint. EVERYTHING is changed. down to a new itr hub. a NEW one that i HAD to machine AGAIN!!!!!!!!!!! balljoints, wheel bearing, tie rods, rotors. i don't know whats next. steering rack and transmission?
MortensenGSR
Jun 21, 2009 10:18 PM
fackyou
Mar 20, 2007 06:44 AM
Jesterian
Mar 20, 2006 11:53 AM
MugenHonda
Jul 26, 2005 12:02 PM
charjacq
Mar 2, 2003 08:31 AM
