A random question please help>>>>>>>>>>>>>>>
Old Mar 14, 2008 | 02:08 PM
rotascircuit's Avatar
Default A random question please help>>>>>>>>>>>>>>>
Hey I went to acura dealership and I bought some stuff and I bought a valve/injector cleaner. It says to use it through a vacume like and have ur engine at 1500 rpm untill the bottle is all out. Anybody knows anything about it? By the way thatis for my 95 gsr. Anybody know what vacume line or anything? THANX
Modified by rotascircuit at 3:56 PM 3/14/2008
Modified by rotascircuit at 3:58 PM 3/14/2008
Old Mar 14, 2008 | 02:46 PM
99Geeezer's Avatar
Default Re: A random question please help>>>>>>>>>>>>>>> (ro
True injector cleaner will go through the fuel lines and not through a vaccum line.
Old Mar 14, 2008 | 03:39 PM
Default Guys need help and advice !!!
Hey I went to acura dealership and I bought some stuff and I bought a valve/injector cleaner. It says to use it through a vacume like and have ur engine at 1500 rpm untill the bottle is all out. Anybody knows anything about it? By the way thatis for my 95 gsr that is in my 95 civic si. Anybody know what vacume line or anything? BTW I read the instructions and tried it and the engine stalled right away so I stopped. Should I use a spray bottle and spray it into the mani? Or WHAT WOULD BE THE BEST THING TO USE TO CLEAN OUT MY INJECTORS? THANX A BUNCH GUYS
Old Mar 14, 2008 | 04:41 PM
pootie.teng's Avatar
Default Re: Guys need help and advice !!! (rotascircuit)
i think you're suppose to slowly suck it in, regulating it. it did mention on the direction to allow 8-10mins to empty the bottle. don't tell me you stuck your vacuum line into the bottle directly without regulating it. if so its going to stall on you right away.
but y didn't you just use the regular stuff you pour into your gas tank?
Old Mar 14, 2008 | 05:01 PM
gsilnc's Avatar
honestly what i would do would be to just take each injector off and clean it by hand, replace the o-rings and bushings and your good
its not that hard of a job, just be sure not to over-tighten your injector rail when you put it back on.
Old Mar 14, 2008 | 05:03 PM
gsilnc's Avatar
Default Re: Guys need help and advice !!! (gsilnc)
^^and just use that cleaner ish for your valves
Old Mar 14, 2008 | 05:06 PM
Default Re: Guys need help and advice !!! (pootie.teng)
I<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pootie.teng &raquo;</TD></TR><TR><TD CLASS="quote">i think you're suppose to slowly suck it in, regulating it. it did mention on the direction to allow 8-10mins to empty the bottle. don't tell me you stuck your vacuum line into the bottle directly without regulating it. if so its going to stall on you right away.
but y didn't you just use the regular stuff you pour into your gas tank?</TD></TR></TABLE>
I did it stalled and i decided to ask out on honda-tech before I continue. were do I get a regulator?
Old Mar 14, 2008 | 05:48 PM
lmike6453's Avatar
regulating it means in regulation...for example...
take off your brake booster vacuum line(by the brake master cylinder) and stick it in as slow as your hand can go into the bottle...
what you are shooting for is a teaspoon at a time with 15 seconds in between so you dont stall or hydrolock your motor...
i do this with seafoam and i recommend that you remove your o2 sensor beforehand, and after done(beating the motor for 30 mins) replace oil and spark plugs
Old Mar 14, 2008 | 09:10 PM
dc2_916's Avatar
u should try using SEAFOAM,,it only cost 7 dollars at autozone or pepboys.. u run it through ur vaccum line and it'll clean all the nasty stuff from ur engine.. search it on youtube to see for urself.. i used it on my geezer and it runs alot better then before..
Old Mar 14, 2008 | 09:52 PM
Rbehne2's Avatar
Default Re: Guys need help and advice !!! (dc2_916)
SeaFoam
Very good stuff
Old Mar 14, 2008 | 10:31 PM
g2daturbo's Avatar
Default Re: Guys need help and advice !!! (Rbehne2)
run it through the vacuum line on the back of the intake manifold going to the fuel pressure regulator
rotascircuit
May 31, 2008 07:27 AM
rotascircuit
Mar 16, 2008 08:27 PM
rotascircuit
Mar 15, 2008 01:20 PM
rotascircuit
11
Mar 14, 2008 10:31 PM
rotascircuit
Mar 14, 2008 05:07 PM
