quick question about turbo setup
Old Oct 5, 2008 | 06:58 PM
2ndchirp's Avatar
Default quick question about turbo setup
Ok i got a block thazz built for boost..... my next decision is wa head to use... well i have 2 perfectly good LS heads ...i was wonderin if i should upgrade the LS head so it can take the boost or should i buy a vtec head like gsr or b16???
Old Oct 5, 2008 | 07:32 PM
AlphaQup's Avatar
Default Re: quick question about turbo setup (2ndchirp)
LSVTAK alone is not as easy as you may think it's made up to be. Since your asking this question, I'm interpreting that you have little to no experience with LSV setups, let alone Forced Induction. I'd suggest you read up (search) and do research as much as you can before you attempt to dive into this world of Boost and LSVtak. There are many archived threads on this forum to help you with the many different variables that you will encounter as you decide to step into the "Darkside".
If you already know the answers, more power to you. LSVT setups produce madd power, as long as you know wtf you're doing.
Old Oct 5, 2008 | 09:53 PM
sjbmx's Avatar
if your allready planing on boost dont even bother with vtec.
Old Oct 6, 2008 | 06:21 AM
AWD Terror's Avatar
Default Re: (sjbmx)
All depends on how much money you want to spend. A half assed LSVT set up will break every time you hit full boost.
If you want good reliability, build the LS head.
Old Oct 6, 2008 | 07:53 AM
shortycm17's Avatar
Default Re: (AWD Terror)
i'd say just build the ls head , valves, springs retainers, port, cams, ls head doesnt flow anything like a gsr head would, but the boost will make up the difference.... unless yr going to properly build yr ls/vtec i.e. take the time to do it right and not just slap a vtec head on yr block . either way u go just dont skimp on your build ..you'll regret it down the road
Old Oct 6, 2008 | 08:10 AM
Spec R's Avatar
Default Re: (shortycm17)
why are you boosting int he first place?
parking lot stunna?
street racer deluxe?
drag strip?
road course?
autocross?
Old Oct 6, 2008 | 07:15 PM
2ndchirp's Avatar
Default Re: (Spec R)
lol.. yea spec r.. street racer... i did research and i see the gsr head is better for all motor and the b16 for turbo because of the low compresion.... but i also been told that ls turbo can be a beast.. well my block includes forged low compression pistons.. light weight crank... ARP head studs and rod bolts with eagle rods and JE pistons.. well if i did go vtec i would use the golden eagle ls/vtec conversion kit... but i have not still made up my mind on which head... i just want something thazz powerfull enough to compete in the streets
Old Oct 6, 2008 | 08:33 PM
EkFG's Avatar
Default Re: (2ndchirp)
just throw the ls head on and boost it with a good tune you'll be rippin' the streets. you could push 10 psi no problem.
Old Oct 6, 2008 | 08:38 PM
Spec R's Avatar
Default Re: (EkFG)
Old Oct 6, 2008 | 11:04 PM
sjbmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spec R &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
ya!!!! well i give it a
Old Oct 7, 2008 | 06:30 AM
AWD Terror's Avatar
Good addition to the thread.
OP: depending on how much money you have and miles on your engine, I would consider boosting the stock engine. I've seen people get a good tune and for it to last for awhile.
While you are running on that engine, you could build up one on the side and wait for it to blow.
Old Oct 7, 2008 | 03:26 PM
2ndchirp's Avatar
yea the LS in my car right now only has around 85,000 .. ill be boostin that until i get my head ready for the other block that i built.. the block that i reffered to on my last post is also sleeved so ill be running some high boost
Old Oct 7, 2008 | 11:13 PM
Spec R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">
if he's building a car for street racing, why should anyone contribute?
Old Oct 8, 2008 | 10:15 AM
Schister66's Avatar
Man U FTW
if he's building a car for street racing, why should anyone contribute? </TD></TR></TABLE>
Good point.
THE END
Rooftop voter
Jan 16, 2008 04:51 AM
dets93teg
Jan 15, 2007 08:09 PM
Mostecstreethb
Oct 27, 2006 08:08 PM
1SickHb
Dec 5, 2005 07:49 AM
