Help Exhaust problem
Old Oct 1, 2008 | 12:39 PM
gonein60seconds's Avatar
Default Help Exhaust problem
ok so i have a 96 ls and i did straight piping with an apexi royal and it sounded great but then i decided to put on some headers (high tech Reps the 2 piece one) n after the headers were on it sounded horrible.... so im pretty sure its not the muffler because it was fine before the headers were on... can anyone help me
Old Oct 1, 2008 | 01:28 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Help Exhaust problem (gonein60seconds)
What does "sounds horrible" mean? Is it raspy? Do you have a resonator? Do you have a catalytic converter?
Old Oct 1, 2008 | 01:46 PM
Default Re: Help Exhaust problem (Dogginator)
no i dont have resonator and it sounds normal ultil i accelerate n the noise is like a loud hi pitch rattle almost
Old Oct 1, 2008 | 01:52 PM
Dogginator's Avatar
Daisy... Daisy...
Do you have the correct donut? I assume the heat shields have all been removed.
Old Oct 1, 2008 | 02:04 PM
it had correct donut... the headers are 2 1/2 and pipe is 2 1/4 but i got the adapter for it with the donut the flange kit that goes from 2 1/2 into 2 1/4..... i think it has something to do with the headers because thats when it all started
Old Oct 1, 2008 | 02:05 PM
whats a good resonator to get?
Modified by gonein60seconds at 3:43 PM 10/1/2008
Modified by gonein60seconds at 6:26 PM 10/1/2008
Old Oct 1, 2008 | 02:09 PM
Dogginator's Avatar
Daisy... Daisy...
Can you make this rattle when revving without moving the car? Is the rear header support installed?
Old Oct 1, 2008 | 03:28 PM
berb_15's Avatar
I'm not an exhaust expert but a resonator would probably help, I'm assuming it's a custom bent exhaust from the cat back?
Old Oct 3, 2008 | 05:03 PM
Default Re: Help Exhaust problem (berb_15)
i just noticed i have a bolt missing at the header support could that be the reason for the sound? and also i have a leak where the two header parts connect.
Old Oct 6, 2008 | 07:33 AM
shortycm17's Avatar
i think u just answered your own question buddy... fix the leak and your raspy noise will probably go away.... LEAKS = ugly sounding exhaust
Exposer03
May 5, 2015 10:15 AM
feriotypeR
19
Sep 17, 2009 09:45 AM
Extreez
Jan 23, 2007 09:23 PM
mugen88crx
Sep 8, 2004 07:54 AM
