what to do about the pcv???
Old Oct 3, 2008 | 03:56 PM
tophastyle's Avatar
Default what to do about the pcv???
im putting a 94 integra intake manifold on a 96 motor. what do i do about the pcv hose because the old one(hose) went to the black box by the oil filter and the new motor shows that it(hose) goes to the valve cover??
Old Oct 3, 2008 | 10:16 PM
vietnamezerice's Avatar
Default Re: what to do about the pcv??? (tophastyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tophastyle &raquo;</TD></TR><TR><TD CLASS="quote">im putting a 94 integra intake manifold on a 96 motor. what do i do about the pcv hose because the old one(hose) went to the black box by the oil filter and the new motor shows that it(hose) goes to the valve cover??</TD></TR></TABLE>
as long as the PCV is going to a vacuum port into the intake manifold you should be good (assuming you're still using a OBD2 valve cover) and if you're using an intake manifold and throttle body a 94 you might experience some idleing problems because only automatic B18b's use the FITV... Manual Integra's use only the IACV
Nickabeans
Jun 11, 2014 02:34 PM
Turbochargedcivic
Aug 2, 2006 08:04 AM
Ri5e
Aug 12, 2002 09:53 PM
GTEater
Nov 8, 2001 07:49 AM
KekeK-18
Jul 12, 2001 05:17 PM
