Transmission problem help
Old Oct 3, 2008 | 10:13 AM
guysensei's Avatar
Default Transmission problem help
I had to tow my brothers car and now I have to figure out what is wrong...Its a 5 speed tranny. It doesn't engage and it makes random banging sounds even in neutral.Also when I was towing it, it smelled like burnt clutch.I'm about to drop the transmission but I was just wondering if this has ever happened to anyone or if anyone has a clue what went wrong???
Old Oct 3, 2008 | 10:32 AM
kronikSLOW's Avatar
Default Re: Transmission problem help (guysensei)
did you tow the car forward or backwards. sounds like you messed up your clutch during the tow. its front wheel drive remember so tow it from the front with the front wheels off the ground. otherwise you will smell burnt rice crispis.
Old Oct 3, 2008 | 10:36 AM
guysensei's Avatar
Default Re: Transmission problem help (kronikSLOW)
Towed it forwards tires on the ground I had no other way.So your saying if it wasn't messed up it probably is now.
Old Oct 3, 2008 | 01:40 PM
guysensei's Avatar
So here is where I'm at. Started to set up to take out the transmission. I turned the car on to hear where the noise was coming from and I noticed that the pass side axle didn't move.It spins but only up to the cv boot that is closer to the wheel. I pulled it out and there is no noise coming out of the transmission anymore. So I don't know if I should drop the tranny and continue.Anyone???
Old Oct 3, 2008 | 01:45 PM
Thrule01's Avatar
im thinking tranny is gone or hurt bad..
best bet may be to just get a replacement one and part that one out...
Old Oct 3, 2008 | 01:58 PM
guysensei's Avatar
Default Re: (Thrule01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrule01 &raquo;</TD></TR><TR><TD CLASS="quote">im thinking tranny is gone or hurt bad..
best bet may be to just get a replacement one and part that one out...</TD></TR></TABLE>
Thanks for the reply that is kinda where I'm at. I kinda hoped the tranny would be alright, but I can't explain why the car would not run just because the pass side axle broke.anyone??
Old Oct 15, 2008 | 05:14 PM
guysensei's Avatar
Default Re: (guysensei)
Awesome well after waiting for forever for a axle, It turns out that the only problem was the broken axle weird but better than the transmission being messed up
Old Oct 15, 2008 | 09:51 PM
vietnamezerice's Avatar
yikes, the motor was turning backwards in you were in a foward gear...
wesk18
Jan 27, 2009 04:03 AM
linhbao
Jul 12, 2007 05:42 AM
Opie
Nov 6, 2003 11:50 AM
turbohf
Mar 17, 2003 01:24 AM
