block guard
Old Oct 2, 2008 | 06:01 PM
nightshift_rolla's Avatar
Default bent valves
i am builbing a ls/vtec motor with SRP dome top high compression pistons and crower stage 2 cams i am worried about the pistons slapping my valves when the vtec kicks anyone with the correct info let me kno???
<<NS-R TEGGY>>
Modified by nightshift_rolla at 7:09 PM 10/2/2008
Modified by nightshift_rolla at 7:13 PM 10/2/2008
Old Oct 2, 2008 | 06:04 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: block guard (nightshift_rolla)
Um.. adding a blockguard won't help protect your pistons from coming in contact with your valves.
Old Oct 2, 2008 | 06:10 PM
my bad someone told me the wrong stuff i looked into it block guard only protects cylinder walls
Old Oct 2, 2008 | 07:54 PM
I AM WEASEL's Avatar
Default Re: bent valves (nightshift_rolla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nightshift_rolla &raquo;</TD></TR><TR><TD CLASS="quote">i am builbing a ls/vtec motor with SRP dome top high compression pistons and crower stage 2 cams i am worried about the pistons slapping my valves when the vtec kicks anyone with the correct info let me kno???
&lt;&lt;NS-R TEGGY&gt;&gt;
Modified by nightshift_rolla at 7:13 PM 10/2/2008</TD></TR></TABLE>
I hope you are not planning on just putting the pistons in, and simply installing the cams? First of all, what is the static compression of the pistons? Are you planning on checking p2v and v2v clearances, degreeing the cams, blueprinting the bottom end ...?
Old Oct 2, 2008 | 08:26 PM
no im not just throwing the pistons and cams in, its going to be fully built top and bottom, valves, springs, retainers, rockers, everything. i will be checking all p2v and v2v clearances, if i need to degree the cams i will but i would rather not. what is blueprinting the bottom???
nightshift_rolla
Oct 2, 2008 07:21 PM
blwn95civic
Oct 12, 2006 01:39 AM
jdmefhondachassis
Aug 17, 2004 10:50 AM
Speedra500
Jun 1, 2004 06:06 PM
baonest
May 22, 2002 06:13 PM
