I need Help!!!!!!!!!!!!!!!! Header?
Old Oct 3, 2008 | 10:34 AM
Topsy_Kretts's Avatar
New User
Default I need Help!!!!!!!!!!!!!!!! Header?
I hv a 94 ls and im putting in a gsr motor, can i use the stock header for now or do i need to buy a gsr header right away. Need info pls!!!!!!!!!!!!!!!!!
Old Oct 3, 2008 | 10:58 AM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: I need Help!!!!!!!!!!!!!!!! Header? (Topsy_Kretts)
Since you're not changing the exhaust, Yes you can use what you have.
Old Oct 3, 2008 | 11:17 AM
Brice.Hayden's Avatar
Default Re: I need Help!!!!!!!!!!!!!!!! Header? (CleanLikeJdm)
if you used a gsr header it would not fit correctly because of the length of the catalytic converter. keep the LS exhaust manifold until you are able to buy a header, test pipe and modify your exhaust length to have it all fit right.
Good luck
Old Oct 3, 2008 | 11:50 AM
guysensei's Avatar
Default Re: I need Help!!!!!!!!!!!!!!!! Header? (Brice.Hayden)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brice.Hayden &raquo;</TD></TR><TR><TD CLASS="quote">if you used a gsr header it would not fit correctly because of the length of the catalytic converter. keep the LS exhaust manifold until you are able to buy a header, test pipe and modify your exhaust length to have it all fit right.
Good luck </TD></TR></TABLE>
Old Oct 3, 2008 | 12:00 PM
New User
Thanks I appreciate it. I gs If i go with and ls header 4 - 1 wud not be a problem. I gs later i will go with a full cat back exhaust.
Old Oct 3, 2008 | 12:01 PM
New User
Default Re: I need Help!!!!!!!!!!!!!!!! Header? (guysensei)
Thanks again.
Old Oct 3, 2008 | 12:03 PM
New User
Wut do u recommend i go with. And where do i get the test pipe. Thats the small extention btwn the cat and the collector right? So shud i go with a full cat back for the LS set up.
Old Oct 3, 2008 | 02:30 PM
Hype-R Stalker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topsy_Kretts &raquo;</TD></TR><TR><TD CLASS="quote">Wut do u recommend i go with. And where do i get the test pipe. Thats the small extention btwn the cat and the collector right? So shud i go with a full cat back for the LS set up.</TD></TR></TABLE>
Buy the exhaust to replace the current one, being a 94 LS, not to match the motor.
And a testpipe replaces the cat, which is pretty much pointless n/a.
1994delsolLS
Mar 2, 2009 01:21 PM
kenzo42
Nov 5, 2007 09:48 PM
little B
May 3, 2007 10:25 AM
H22A_HB
Nov 11, 2004 08:21 PM
jaystation
Oct 9, 2004 03:02 AM
