HELP! header wrap how to ?
A clean header helpful.
Soak wrap in water, wrap around tubes, overlap at the start to prevent unwrapping, clamp loose end. Allow to dry some, drive car, exhaust heat will finish drying and the wrap will shrink slightly, keeping it in place.
better than header wrap buy the one that just has little clip ons.
but if you decide the header wrap way.
have the header off the car best way.
wet wrap
wrap around header "stay away from welds"
let it dry
then spray with high temp header spray
let it dry then install.
wet wrap
let it dry
96hatchBoy
Oct 26, 2012 09:14 AM
