what should my fuel pressure be at idle?
right now my fuel pressure is a drop over 50 at idle
is that too high?
also what would happen if i removed the FMU and bumped the pressure up with the B&M regulator?
cause like i stated in my post last night, i'm running super rich and tons of smoke is coming from the tailpipe when ever i boost
is that too high?
Re: what should my fuel pressure be at idle? (rbf351)
I have mine running at 42psi which seems to work well. It was running around 50psi and I was having the same issue as you.
TedR719
09-08-2004 02:57 AM
preluder
07-14-2003 10:36 AM
