What is the MAP SENSOR Volt reading for Integras??
Old Nov 25, 2002 | 03:03 PM
Mr.DC2TurBo's Avatar
Default What is the MAP SENSOR Volt reading for Integras??
I'm having a hard time finding the MAP sensor on my 2001 LS Integra. I need it to run the s-afc. Supposely in the helm book, the map sensor is color white/yellow but my ecu does not have those colors. Then someone told me it's pin c17. I haven't tapped into it yet b/c I don't know what will happen if this is wrong and I don't want to buy a new afc or ecu if I fry it. So, does anyone have a VOLT METER reading for their MAP Sensor so I can make sure pin c17 is the same readings as older integra's map sensor. PLease help, thanks...
Old Nov 25, 2002 | 03:12 PM
Jared's Avatar
Default Re: What is the MAP SENSOR Volt reading for Integras?? (Dr.TurBo2006)
As I remember, its about 2.26V with key on, engine off.
Old Nov 25, 2002 | 03:41 PM
filetofit
Guest
Posts: n/a
2.26 would be at altitude, 2.9 at sea level.
Old Nov 25, 2002 | 03:54 PM
Default Re: What is the MAP SENSOR Volt reading for Integras?? (filetofit)
thanks for the help, what does sea level mean? I'm in PA so what is that.
Old Nov 25, 2002 | 04:07 PM
filetofit
Guest
Posts: n/a
LOL, Pennsylvania is sea level, I meant that Denver or Salt Lake City would be a lower voltage.
Old Nov 25, 2002 | 04:36 PM
thanks. so you guys are sure it's 2.9 at sea level or 2.26 in middle US??
Old Nov 25, 2002 | 04:56 PM
filetofit
Guest
Posts: n/a
I'm about 4 blocks away from the beach and I measure 2.9 volts with a digital voltmeter.
Old Nov 25, 2002 | 05:35 PM
I Like Boost's Avatar
2.26 in the middle of the us, that's funny . sea level is the has to do with the level of the ground, how high it is (mountins) or how low it is(vally) compared to the flat sea level of the earth. how far did you make it in school?
Old Nov 25, 2002 | 08:23 PM
Default Re: What is the MAP SENSOR Volt reading for Integras?? (BEe18SeAONe)
Dude what is your problem, all I asked was for some help? If you don't want to help then F@cK OFF... All I asked was what does sea level mean b/c I never heard that express before... If you really want to know how far I got in my education, I graduate from UC DAVIS with a 3.56 gpa (bio engineering).. Now I'm doing my Pharm D. at University oF the Sciences in Philadelphia (completion in 2006... Therefore, the name Dr.Turbo2006). Anything else??? So BEe, how far did you get?? 1st grade or am I giving you too much credit.
Benny Bao
Oct 14, 2014 11:47 AM
baulum
Apr 13, 2008 10:18 PM
scUba-stEve
Aug 26, 2005 12:14 PM
