Radiator Fan Relocation (pics)
Old Nov 23, 2002 | 09:03 PM
philo's Avatar
Default Radiator Fan Relocation (pics)
I needed more room for my turbo setup so I changed both my stock fans for universal pusher fans. $60 each and do a great job, they seem to be quite a bit more effective than the stock fans. Working on the turbo is much easier and all my intake piping fits perfectly.
All Pics (UPDATED) - http://www.uplinked.net/users/philo/civic/index.htm
[Modified by philo, 4:47 PM 11/24/2002]
Old Nov 23, 2002 | 09:04 PM
FBP Si 2000's Avatar
Default Re: Radiator Fan Relocation (philo)
Old Nov 23, 2002 | 10:00 PM
Silverbeast's Avatar
Default Re: Radiator Fan Relocation (FBP Si 2000)
nice fans... where did you see those first?
Old Nov 23, 2002 | 10:13 PM
accordfreak's Avatar
Default Re: Radiator Fan Relocation (HoustonSi)
so the advantage of moving your fans is to have more room and it doesn't negatively affect the temp of the car right?
edit: the black box bolted in front your electronic boost controller?
[Modified by accordfreak, 7:18 AM 11/24/2002]
Old Nov 23, 2002 | 10:21 PM
mos's Avatar
mos
Default Re: Radiator Fan Relocation (accordfreak)
Nice fans, nice price. How do those things grab on?
Old Nov 23, 2002 | 10:31 PM
philo's Avatar
pusher fans are actually better at pushing air through the radiator than a similar puller fan can pull air through. these fans cycle off a lot quicker than the stock fan which would suggest its bring the temp down quicker.
the fan anchors by pushing a kinda zip tie through the core and uses foam pads to prevent damage. I have used these on other projects and they dont seem to cause any damage to the core.
Old Nov 23, 2002 | 10:52 PM
The Mole's Avatar
how are they wired/hooked up....come on like stock or did you have to use a new thermo type switch?
chris
Old Nov 23, 2002 | 11:14 PM
philo's Avatar
Default Re: Radiator Fan Relocation (The Mole)
They are wired just like stock, i may do a manual override at some point when i start taking it to the strip.
Old Nov 24, 2002 | 12:25 AM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
whered u get em? looks good
Old Nov 24, 2002 | 01:18 AM
Cramerox's Avatar
Default Re: Radiator Fan Relocation (PreIudeSI)
pep boy fans? hehe look like mine
Old Nov 24, 2002 | 07:22 AM
philo's Avatar
Default Re: Radiator Fan Relocation (Cramerox)
These are actually Autozone, Pepboys were $5 more for exactly the same thing. I know Summit have them also. A few peeps had IMd me asking for the part number so here it is 226112.
Its a very easy install, just remember to reverse the polarity from the factory fans, both are color coded black and blue.
Old Nov 24, 2002 | 09:06 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
that sheit looks cool, i might have to do that with mine also, being that my wastegate is ON my fan, and i had to cut it, and it sux, good job
Old Nov 24, 2002 | 10:53 AM
TurboDANDEE's Avatar
Default Re: Radiator Fan Relocation (SIXTYdashONE)
I have the same fans on my civic. Are yours 10" or 12"? I have a 10" on my condenser and 12" on my radiator.
Also, how did u mount your condenser because the brackets on it are on the stock fans.
[Modified by TurboDANDEE, 1:54 PM 11/24/2002]
Old Nov 24, 2002 | 11:51 AM
B18EG6's Avatar
really nice...Im jealous. Two questions though...
1.) damn man did you use earls fittings for the vac port on the side of the wastegate?
And pardon my stupidity...but what is this for?
Old Nov 24, 2002 | 12:15 PM
philo's Avatar
Default Re: Radiator Fan Relocation (TurboDANDEE)
Mine are both 12" 850CFM units, i could have probably used a smaller fan on the A/C condenser but I liked the way the 12" fitted and it cycles off much quicker than the stock unit.
I was going to make a new bracket for the A/C condenser but I ended up mounting it temporarily with a few heavy duty zip-ties and that worked really well. Maybe once i finish my down pipe and I see where everything ends up I may make a bracket.
The line coming off my intercooler goes to the boost controller which is mounted just behind it. Some folks go off the intake piping but this way is cleaner and should give my controller quicker response.
[Modified by philo, 3:17 PM 11/24/2002]
Old Nov 24, 2002 | 12:16 PM
Cramerox's Avatar
Default Re: Radiator Fan Relocation (B18EG6)
thats prolly where he gets the wastegate vacuume signal from.
Old Nov 24, 2002 | 04:19 PM
MugenGTR's Avatar
i still don't get how u mouned those?
Old Nov 24, 2002 | 04:29 PM
Cramerox's Avatar
Default Re: Radiator Fan Relocation (MugenGTR)
Its basically like a zip tie. You take the mounting accessory and string it through the radiator fins. But it doesnt loop like a ziptie, you have like a "nut: on the other side that secures the tie so it doesnt fall off
Old Nov 24, 2002 | 04:49 PM
01geeser's Avatar
New User
that goes to his boost controller as you can see in the other pic.
Old Nov 26, 2002 | 07:01 PM
EU BATT's Avatar
I got a set of those ramps too! They work great! By the way...You didnt need a relay for the fans did you?
Old Nov 26, 2002 | 07:12 PM
philo's Avatar
Default Re: Radiator Fan Relocation (EU BATT)
They wire straight in to the stock harness, just reverse the polarity. No relays needed.
Old Nov 26, 2002 | 07:26 PM
blu_si's Avatar
Hey on your SBC-ID Blitz boost controller did you have a vacuum hose goin from the out side of the black box? Cause i don't see it in the pictures. Just wondering cause i have the same boost controller and have been wondering the correct way to hook it up for quite some time.
[Modified by blu_si, 8:31 PM 11/26/2002]
Old Nov 26, 2002 | 07:35 PM
SiRkid's Avatar
Default Re: Radiator Fan Relocation (blu_si)
Old Nov 26, 2002 | 07:40 PM
AlphaKennyWun's Avatar
Default Re: Radiator Fan Relocation (SiRkid)
my gsr radiator is not that small...wonder if I could fit that in mine...hmm
Old Nov 26, 2002 | 07:43 PM
FredoSP's Avatar
kewl, looks good
