What piston size do I need for B18C1??
Old Nov 25, 2002 | 06:32 PM
speedy108's Avatar
Default What piston size do I need for B18C1??
I am will be putting pistons in my '99 GSR and will not be pulling the block out of the car. I know that the bore is 81mm. I plan on doing 9:1 Comp. pistons with stock bore, and all I will be doing is honing it.
What size (bore) will I need to get if I'm just honing? Just 81mm?
Thanks, Michael
Old Nov 25, 2002 | 06:50 PM
ekb18c's Avatar
Default Re: What piston size do I need for B18C1?? (speedy108)
huh?
When you do a hone job on the block, all your doing a creating a cross hatch on your cylinder wall.
Old Nov 25, 2002 | 07:24 PM
HybridKOOP's Avatar
Default Re: What piston size do I need for B18C1?? (ekb18c)
huh?
That depends on how many passes with a hone device you do. Too many passes and you're moving into "bore" territory.
I PERSONALLY would recommend pulling the block to do a full overbore (.020) with oversize pistons.. but if thats out of the question, and you just throw a new crosshatch on the walls, yes... you will order a 81mm piston set.
raverx3m
Jun 10, 2014 10:55 AM
hYbRid_Eg6
Mar 16, 2010 07:40 AM
stocker2shocker91
13
Oct 17, 2007 09:33 AM
turboex
Mar 1, 2004 11:11 AM
B pwr
Mar 26, 2003 10:44 AM
