fuel pressure question for guys with fp gauges
Old 11-25-2002, 03:56 PM
civbeater90's Avatar
Default fuel pressure question for guys with fp gauges
ok guys once you turn your key and the pump turns on,your pressure usually rises.what happens to your pressure if you dont start your car?does the pressure drop even though you have your key turned or does it stay presurized?
Old 11-25-2002, 04:23 PM
b16ahybrid's Avatar
Default Re: fuel pressure question for guys with fp gauges (civbeater90)
mine drops back down to zero.I believe there is still fuel pressure there (actually i know).why it doesn't register i don't know.Because if you were to unscrew the banjo nut on your fuel filter you would get sprayed with fuel (go ahead ask how i know ).
Old 11-25-2002, 04:26 PM
Default Re: fuel pressure question for guys with fp gauges (b16ahybrid)
ok thanks im just trying to elimnate the possiblity that my pump is bad.i cant get my injectors to pulse
Old 11-25-2002, 04:28 PM
b16ahybrid's Avatar
np...check your wireing
Old 11-25-2002, 04:50 PM
yeah i have and everything that should have continuity does etc.but my injectors dont get pulsed to ground for some reason
aemlet
Honda Civic (2001 - 2005)
10-14-2013 08:12 PM
hybridpatient95
15
02-10-2006 07:03 AM
monicle
03-29-2004 01:37 PM
Z6REX-SI
01-13-2004 11:13 AM
TRuST
03-12-2002 09:44 AM
Quick Reply: fuel pressure question for guys with fp gauges
