broken bolts
Old Nov 25, 2002 | 02:13 PM
syndicate43's Avatar
Default broken bolts
I was putting my head back togther today and the cam holder bolts broke and there are peices stuck in the threads does anyone have a good way to remove the peices. any help would be great
Old Nov 25, 2002 | 04:15 PM
DeepSi's Avatar
Default Re: broken bolts (syndicate43)
You might be able to use a reverse drill bit to get it out. I dont know exactly which bolt you are talking about, but usually this works to get out broken bolts.
Old Nov 25, 2002 | 04:57 PM
ChiBoy's Avatar
Post a pic, if you can. Someone will have an idea for you.
Old Nov 25, 2002 | 05:04 PM
filetofit
Guest
Posts: n/a
They make tools to do this. Basically you drill a small pilot hole in the bolt with a smaller bit and then put the special tool in your drill, put the drill in reverse and it'll grab the bolt and turn it out. I think they are called Easy Outs, I've used one they work.
Old Nov 25, 2002 | 05:49 PM
ninesecrx's Avatar
Default Re: broken bolts (filetofit)
Thats it...those bolts suck. I have broken a few my self cause they get weak when you have to pull apart a motor so much. Just make sure your not over tightening them too much and go slow because you can actually feel them twist before they break. They do give you a warning, but you have to go slow. Make sure you cover the head when doing the drilling process so no flakes get into the head and dip the drill bit in some thick grease so it will also help in collecting the metal flakes.
HotCheetos
10
Dec 11, 2010 09:07 PM
cedrichawkda6
Suspension & Brakes
Aug 3, 2010 09:30 AM
bdubnyc
13
May 13, 2008 10:16 AM
Timberland237
Suspension & Brakes
Nov 9, 2006 11:29 AM
Nice_Dc2r
Oct 23, 2003 10:41 AM
