should I do a clutch install at the same time I do my turbo install?
Clutch already starts to slip on the stock b18b.
..just wondering if I should install a new clutch first, then install turbo?
would it be any easier to install the clutch with some parts out of the way?
..what clutch would you guys recommend for ~8psi daily driven (stop, go traffic @ times - so as close to stock feel)
Thanks
-Justin
Thanks
-Justin
Re: should I do a clutch install at the same time I do my turbo install? (pub)
Either order, but put it in before you boost... or you will be pissed on how bad it slips.
ACT hybrid street disc with extreme pressure plate.
Re: should I do a clutch install at the same time I do my turbo install? (HybridKOOP)
I put my ACT street disc with extreme pressure plate clutch in before I installed the turbo. If you are going to install the turbo soon then just do them both together, otherwise do the clutch first.
Re: should I do a clutch install at the same time I do my turbo install? (ski_rebel_3)
Install the clutch before and break it in. then install the turbo and tune it and emjoy it. ACT HDSS here and loving it in the Bay Area traffic.
Re: should I do a clutch install at the same time I do my turbo install? (DeepSi)
go with an ACT Xtreme Plate with the hybrid street disc
jabronee76
10-18-2003 10:58 PM
Snafu-Si
05-30-2002 11:36 PM
