Greddy Blue Box - White Wire Connection???
Ques. 1: It looks like you connect the Green and White wires on the Blue Box, do you?
Ques. 2: I know you connect this to the MAP Sensor, but there are 3 wires that I can connect it to: Red/Yellow, White, Green/White. Which one do i connect it to?
[Modified by Maverick77, 4:17 PM 11/22/2002]
Re: Greddy Blue Box - White Wire Connection??? (Maverick77)
what it looks like to me is you just hook it into the one wire that goes to that pin on the ecu (which is D17)....
so...cut this wire and use those conectors to connect the green wire to the side that goes directly to the ecu (D17 pin), then connect the white wire to the other half of the wire you cut, (the portion that leads out to engine harness)
im not 100% sure, but i belive im correct
Chris
Chris
Re: Greddy Blue Box - White Wire Connection??? (The Mole)
Chris
Chris
