So who's using motor mount inserts?
Old Nov 22, 2002 | 10:55 PM
FBP Si 2000's Avatar
Default So who's using motor mount inserts?
I'm thinking about getting some...just wanted to find out what you guys thought of them...
Old Nov 22, 2002 | 11:19 PM
Accord94DX's Avatar
Default Re: So who's using motor mount inserts? (FBP Si 2000)
car shakes a lil more at idle, NO MORE WHEEL HOP!!! w00t!!!
amazing considering the stupid thing puts out the torque of a diesel (192ft/lbs)
still slow.
Old Nov 23, 2002 | 01:04 AM
sporkcrx's Avatar
Default Re: So who's using motor mount inserts? (Accord94DX)
i have some and i love em! both the mounts that got em were both ripped so it made a BIG difference...just made the car feel real solid. Definetly a good buy for $20
Old Nov 23, 2002 | 02:28 AM
VaporTrail's Avatar
New User
have them in my GSR. Love them for the lack of movement, motor is rock solid, and shifts are more consistant in feel because of it. I hate them due to the vibration, but it only really vibrates at idle with the a/c on. Oh well.
Old Nov 23, 2002 | 04:53 AM
Jared's Avatar
Default Re: So who's using motor mount inserts? (VaporTrail)
I used Lord's 1-2-3 seam sealer in mine. much stiffer than urethane.
Old Nov 23, 2002 | 06:36 AM
Farnsrocket's Avatar
Default Re: So who's using motor mount inserts? (Jared)
ditto
Plus, your take off in 1st gear seems more defined/solid. Also, giving the car gas during cruising feels solid.
The first time I started my car with them in, it freaked me out, everything shook differently.
Old Nov 23, 2002 | 06:46 AM
PM-Performance's Avatar
Default Re: So who's using motor mount inserts? (Farnsrocket)
i got em , and love em , good deal for the $30 or whatever they were.
AlphaKennyWun's Avatar
Im going to get them b/c my stock rear mount has disintegrated due to strong clutch engagement from my CM 4.....If you have a clutch like this one then the inserts are a must
Old Nov 23, 2002 | 09:27 AM
Default Re: So who's using motor mount inserts? (SO3Burner)
Sounds good...I'll probably get them now.
Old Nov 23, 2002 | 09:29 AM
boosted3g's Avatar
i wouldnt waste your time with the inserts. Ive torn so many sets of them. Give this site a try. www.jimfab.com
Old Nov 23, 2002 | 10:33 AM
ski_rebel_3's Avatar
From what I understand, both Energy Suspension and Prothane make mounts that we can use but the Prothane kit is much stiffer than the Energy Suspension kit.
Which brand are you guys finding to be the best for a daily driver?
Old Nov 23, 2002 | 10:49 AM
Adi Radoncic's Avatar
On Fire!
Default Re: So who's using motor mount inserts? (ski_rebel_3)
This is kinda off topic but did any of you guys take the two front engine mounts off totally? I'm talking about the mount that is bolted on to the front drivers side of the engine and also holds the A/C pump on the b Series engines anyways..
And than the other one is the mount that holds the transmission on the side again no the main mount but the little helper one...
I have seen a lot of drag cars without them and I was thinking maybe they are not really needed if you had the inserts or even full polyurithane mounts..
Any thoughts, answers or comments on this would be appriciated....
Adi
Old Nov 23, 2002 | 11:00 AM
Canuk_SiR's Avatar
Default Re: So who's using motor mount inserts? (newgsr)
when I removed AC in my car, I removed the mount completely, haven't had a problem with engine stability or anything, no increased wheel hop, nothing. I still have the one on the other side of the engine bay, near the tranny.
Old Nov 23, 2002 | 01:03 PM
Where can I find that? TIA
Old Nov 23, 2002 | 01:04 PM
mskibbz-T's Avatar
Default Re: So who's using motor mount inserts? (Canuk_SiR)
I've had a set of ES motor mounts boxed up in my trunk waiting until the turbo kit goes on.... Sounds like they will feel more noticeable than I originally expected
Old Nov 23, 2002 | 01:06 PM
The Poopsmith's Avatar
I have energy suspension and prothane mounts on my GSR right now. At idle everything shakes, but over 900rpm everything is solid.
Old Nov 23, 2002 | 01:15 PM
InfamousRS's Avatar
Default Re: So who's using motor mount inserts? (boosted3g)
Those should fit in a 94+ teg too shouldn't they?
Old Nov 23, 2002 | 01:22 PM
boosted3g's Avatar
Default Re: So who's using motor mount inserts? (InfamousRS)
I have them for my 97 teg so yeah they will work. His prices cant be beat also. The last thing i would do is take out the torque mounts, your asking for trouble if you do that.
Extreez
Mar 5, 2008 05:11 AM
josedc5s
11
Jun 19, 2007 08:22 AM
94IntegraLs04
Mar 24, 2005 07:16 AM
bearboy80
Jul 9, 2003 01:49 PM
