Please help, what could be wrong with my profec b?
Old Nov 23, 2002 | 03:46 PM
SilverLudeSi's Avatar
New User
Default Please help, what could be wrong with my profec b?
I went to the dyno today to get tuned by sgt, but my boost controller wasn't working right. When steve tried to turn up the boost, it would just increase the slightest bit. He ended up turning the **** way up (to what should have been 15-20 psi), but it still wouldn't boost over ~9 psi. When we hooked up a manual boost controller, everything worked fine, so it has to be the profec not working. I checked everything and it seems to be hooked up right. So, what's wrong? Thanks guys.
Old Nov 23, 2002 | 05:44 PM
Jared's Avatar
Default Re: Please help, what could be wrong with my profec b? (SilverLudeSi)
how did you have it hooked up? what did you set the jumpers on? gain?
Old Nov 23, 2002 | 06:27 PM
New User
Default Re: Please help, what could be wrong with my profec b? (Jared)
It's hooked up with one port of the stepper to top wastegate port, other port tee'd to side port of wastegate and compressor housing. Dip switches were set up for external wastegate, no overboosting. I should go check them just to be sure though, but I don't think that's the problem.
Old Nov 24, 2002 | 12:35 PM
New User
anybody? is there any way to tell if the boost controller itself is broken?
Old Nov 24, 2002 | 01:22 PM
swrdply400mrelay's Avatar
ok i'm looking at the instruction manual for the profec b, it looks like for an external wastegate, the side port of the wastegate should go to the intake manifold. then you run a line from the intake manifold to the "IN" port of the stepper motor. is that what you have? hope this helps
Old Nov 24, 2002 | 01:48 PM
New User
Default Re: Please help, what could be wrong with my profec b? (swrdply400mrelay)
well i am using the compressor as the boost source for the in port instead of the im. This is what people suggest usually.
Old Nov 24, 2002 | 10:19 PM
really? it just doesn't seem like the compressor housing could be as reliable as the im for pressure. used to have a mbc, and it would never hold boost running off the compressor. i ran a line to the im and it held boost, but now i have the profec b (rss for traction)
Old Nov 24, 2002 | 10:24 PM
MiraiZ's Avatar
I have a profec B as well and it spike like a **** with a Tial 35mm...I heard that if you do it the way the intructions say to do it, it won't work...and that you should use the top port of the WG for anything
Old Nov 24, 2002 | 10:25 PM
New User
I don't know, that was the preferred set-up it seemed a few months ago. Maybe I will try using the IM since I have nothing else to try.
Old Nov 24, 2002 | 11:13 PM
Adi Radoncic's Avatar
On Fire!
You have it installed correctly for the most part the only thing you need to do is get read of the T you put in that goes to your turbo compressor housing and plug up the hole on your turbo and you should be set and ready to go...
Adi
Old Nov 24, 2002 | 11:28 PM
New User
Default Re: Please help, what could be wrong with my profec b? (newgsr)
Adi
I don't see how that would work, because then you have no pressure source for the stepper. By the way, sgt (steve sakai) confirmed that my set-up was correct, and I think he has tuned enough turbo honda's to know. So guys, I really don't think the hook-up is my problem.
[Modified by SilverLudeSi, 3:32 AM 11/25/2002]
Old Feb 23, 2003 | 02:36 PM
IloveNewt's Avatar
Hi, im just bringing this one back from the dead to see if anyone has any ideas on the problem. I bougth this car and this problem is still there. Any thoughts?
Old Feb 23, 2003 | 02:43 PM
niedejb's Avatar
Default Re: Please help, what could be wrong with my profec b? (MordecaiPSI)
Try this:
Compressor nipple to IN
OUT to the side of the Tial (leaving the top open to air)
I swear it'll work. I have this configuration on my car and couldnt get any others to work.
Old Feb 23, 2003 | 03:31 PM
IloveNewt's Avatar
Default Re: Please help, what could be wrong with my profec b? (niedejb)
Bringing this back from the dead....
Im gonna try the internal wastegate setup described above. Are there any negative effects of runnin such a setup on an external WG?
Will it hold boost corectly, and does anyone else run it this way?
Modified by MordecaiPSI at 12:45 AM 5/7/2003
prezioso01
Mar 18, 2016 03:54 PM
CX-T
Jun 19, 2008 09:22 AM
hold your breath
Mar 6, 2007 07:47 PM
integraboosted
Jun 23, 2005 11:59 AM
ATS*Mark
Feb 2, 2004 04:22 PM
