Greddy downpipe, cat solution
Old Nov 22, 2002 | 03:03 PM
Cyrio's Avatar
Default Greddy downpipe, cat solution
I want to get a good high flow cat but i dont know what kind fits a greddy turbo kit downpipe. what should i get? and which exhuast?
Old Nov 22, 2002 | 03:25 PM
falcongsr's Avatar
What is this crap?
Default Re: Greddy downpipe, cat solution (Cyrio)
good question.
i got a thermal exhaust and i am not sure how i am gonna get a 3" cat and a flex pipe in before the thermal exhaust.
Old Nov 22, 2002 | 03:31 PM
willyboyK20's Avatar
Default Re: Greddy downpipe, cat solution (falconGSR)
the flex pipe could apart of the overall downpipe length. Thats how mine is. It is apart of the downpipe.
Old Nov 22, 2002 | 04:11 PM
FBP Si 2000's Avatar
I wouldn't mind knowing this.
Old Nov 22, 2002 | 04:37 PM
Cyrio's Avatar
Default Re: Greddy downpipe, cat solution (FBP Si 2000)
At least i finally asked a good question.
Is there a way to get a 3'' cat on without getting a new downpipe?
Old Nov 22, 2002 | 04:41 PM
VTC_CiViC's Avatar
The stock GReddy DP is meant to bolt up to a stock civic cat, so any cat that would replace a stock unit will work.
Old Nov 22, 2002 | 04:44 PM
ZygSpeed's Avatar
I'm having something made for my setup.
He'll finish it up by closed-looping the WG into the downpipe, and then send it out to get coated like the rest of the turbo hot side.
https://honda-tech.com/zerothread?id=338045
P.S. Chris, I might try and make it out that way prior to the ITR EXPO in April.
Old Nov 29, 2002 | 12:58 PM
Cyrio's Avatar
Default Re: Greddy downpipe, cat solution (Zygspeed)
yah
Old Nov 29, 2002 | 01:04 PM
falcongsr's Avatar
What is this crap?
at this point i am planning on cutting the front flange off an old cat, welding on a 2" to 3" flare, and then running a 3" flex pipe to the 3" thermal exhaust.
i'll get a cat once i figure out how much room i have.
Old Nov 29, 2002 | 05:33 PM
tony1's Avatar
Default Re: Greddy downpipe, cat solution (falc0n)
Or, I could build you a 2.5" downpipe that flares out to 3" with a flexpipe that bolts up to the thermal exhaust. How's that sound?
Old Nov 29, 2002 | 05:42 PM
Default Re: Greddy downpipe, cat solution (VTC_boost-less_CiViC)
hey vtc the end of the downpipe u sold me bolts to a 3-inch cat right?
Old Nov 29, 2002 | 05:54 PM
CzanSOHC's Avatar
Default Re: Greddy downpipe, cat solution (willyboyD16)
sounds good, but expensive
Old Nov 29, 2002 | 06:34 PM
falcongsr's Avatar
What is this crap?
Default Re: Greddy downpipe, cat solution (tony1)
it sounds good. i am just trying to be a cheap ***.
will you remove the stock greddy downpipe and give it to me unadultered so that i can reinstall it pending future emissions testing? i guess you'll be able to weld a 'tang' for that bracket and have the 2.5" to 3" flare and 3" flexpipe immediately after it?
sorry i didnt catch up with you tony, been out of town. return tomorrow. let me know when you're at the shop again and i'll head over.
9818tegr
Apr 30, 2008 05:36 AM
drumminforev
Oct 3, 2006 04:37 AM
bmm89
Apr 1, 2002 02:56 PM
turboex
Jan 13, 2002 07:42 PM
