oil pan issues
Old Nov 23, 2002 | 10:09 AM
rjardy's Avatar
Default oil pan issues
I just bought my car a while ago and just did the first oil change yesterday (2000 miles) well im going turbo and here is my question. I noticed that i have a cast aluminum oil pan WTF!! I want a regular stamped oil pan like on all other hondas, so i can weld to it easier. What year civic comes with the pan im looking for? Car is a 2000 ex, thats a d16y8. I am hoping that other pans from earlier civics will fit.
Thanks
Rob
Old Nov 23, 2002 | 10:23 AM
rjardy's Avatar
Default Re: oil pan issues (rjardy)
bump for me i need help!!
Rob
Old Nov 23, 2002 | 10:26 AM
CzanSOHC's Avatar
i'm pretty sure that the y7 is not aluminin, i'll find out for sure later this week.
Old Nov 23, 2002 | 10:31 AM
rjardy's Avatar
Default Re: oil pan issues (CzanSOHC)
is that just the NON vtec motor? im not to up with the d series stuff yet
Thanks
Rob
Old Nov 23, 2002 | 10:39 AM
CzanSOHC's Avatar
yea, non vtec, LX,DX,CX motors....but the blocks are the same, except for the oil pans.
Old Nov 23, 2002 | 10:43 AM
rjardy's Avatar
so i can go to the junk yard and get a pan off of a lx or something? and it should be stamped sheet metal?
Rob
Old Nov 23, 2002 | 12:47 PM
civicwagonman's Avatar
I would think it would be easier to just drill and tap the aluminum, but i've not actually seen one of the aluminum pans, so I don't know how thick they are.
Old Nov 23, 2002 | 12:52 PM
mos's Avatar
mos
Default Re: oil pan issues (civicwagonman)
Just braze a fitting on. You can get a aluminum brazing kit from mcmaster.com for less than five bucks. It should braze aluminum to a brass or non-ferrous fitting no problem. Maybe you can brass or bronze braze it too, not sure about that tho.
You will need a torch of some kind...
[Modified by mos, 1:53 PM 11/23/2002]
Old Nov 23, 2002 | 12:57 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: oil pan issues (mos)
Rob, have someone weld an alumninum fitting to it. Ask dustin about the story at SEMA when he talked to the Miller welder guys. He'll probably remember if you say the Ion story..hehe
art
Old Nov 23, 2002 | 01:09 PM
InfamousRS's Avatar
Default Re: oil pan issues (Arturbo)
COMPLETLY OFF TOPIC!!!
Life is too short, so love the one you got. Cuz you might get run over or you might get shot.
art
Ahhhh....takes me back to my sophmore year in high school when my mom threw my Sublime CD away...hehe
Old Nov 23, 2002 | 01:15 PM
T-sohctec's Avatar
I tried to do the same thing (stamped pan on a Y8) and I had trouble fitting it so I just tapped the aluminum one, they are diesel. Ohh and by the way if you do end up using a stamped pan SELL ME THE Y8 PAN!!!
Old Nov 23, 2002 | 01:16 PM
mos's Avatar
mos
Default Re: oil pan issues (InfamousRS)
Aluminum brazing is VERY strong. You can even do it with one of those small blue propane torches. It would be perfect for putting an aluminum fitting onto an aluminum oil pan. Less heat than welding, so there is not as much chance for warpage to occur.
Old Nov 23, 2002 | 01:41 PM
xci_ed6's Avatar
I would say just tap the pan. no need to weld.
-Dustin
Old Nov 23, 2002 | 02:00 PM
rjardy's Avatar
Default Re: oil pan issues (Autocratic_1st_Gen)
so you guys think that i should just keep this pan that i have and have it tapped? or weld/braze a fitting onto it? Where can i get the bung that needs to be welded/braxed to it? or since it is kinda thick casting perhaps a tap will work? what do you guys think?
Art, i will talk ot dustin about it to
Rob
Old Nov 23, 2002 | 03:37 PM
blufke's Avatar
couldnt u just use a bulkhead?
Old Nov 23, 2002 | 04:59 PM
rjardy's Avatar
Default Re: oil pan issues (blufke)
yeah i supose i could just use a bulk head fitting. i have a bunch of AN fittings here, what size should i use for the return?
Rob
Old Nov 23, 2002 | 05:22 PM
boostaholic's Avatar
10AN is fine
Old Nov 23, 2002 | 06:41 PM
Farnsrocket's Avatar
Default Re: oil pan issues (boostaholic)
Why don't you want to weld an aluminum fitting on it??
Old Nov 24, 2002 | 08:38 AM
rjardy's Avatar
Default Re: oil pan issues (Farnsrocket)
Because all that i have is an old oxy actylyn torch and a MIG welder, i guess i could just go and get it done but i like to do it my self. i think that i will just use a bulkhead fitting.
thanks Guys
Rob
Old Nov 24, 2002 | 10:56 AM
tony1's Avatar
I weld a fitting on all the aluminum pans I do. Just find a good tig welder and pay him a couple bucks to weld the fitting on.
Old Nov 24, 2002 | 11:00 AM
turbod16y8's Avatar
Default Re: oil pan issues (tony1)
i tapped my aluminum oil pan never leaked once.. and its been a year
sikid111
Jan 31, 2019 07:14 PM
STN_Pat
Nov 29, 2012 04:05 AM
ddong2lee
Feb 15, 2004 04:28 PM
