need help difference between b18a and b18b
Old Nov 24, 2002 | 02:28 PM
racecarpete's Avatar
Default need help difference between b18a and b18b
Ok i tried the civic forum and the tech forum so now i am turning to you guys. I have been in the market for a b18b block that i can have sleeved and build for turbo. Yesterday i got offered a bare b18a block w main caps for 50 bucks. I don't knoww much about the b18a so i am asking what the difference between the b18a and b18b? Also can i still add a b16a2 head or will i have to run an older b16 head. thanks.
Old Nov 24, 2002 | 03:06 PM
Default Re: need help difference between b18a and b18b (SilverCivic2k)
anyone?
Old Nov 24, 2002 | 03:09 PM
avividmemory's Avatar
it will work if you use the b18a block...they are more or less the same in my opinion...both are ls blocks
Old Nov 24, 2002 | 03:11 PM
Default Re: need help difference between b18a and b18b (SpoolinLS)
so will it work exactly the same? i heard something about the b18a being different cause it has a breather box. Also, will i be able to use a b16a2 head? thanks
Old Nov 24, 2002 | 03:30 PM
ChiBoy's Avatar
My understanding is that the blocks were essentially the same except for the mounts. I think the driver’s side mount is different, but that you can change the part that bolts to the block on that side and it will fit. I don't want to say this to be absolutely true, but maybe someone can confirm for sure.
Old Nov 24, 2002 | 03:41 PM
Default Re: need help difference between b18a and b18b (ChiBoy)
i was told they are essentially the same once you take the sensors off, is this true??
Old Nov 24, 2002 | 05:18 PM
93LSivic's Avatar
THey are identicle. I blew by b18b and replaced it with a b18a block. Only difference I saw was some type of a coolant sensor above where the oil feed is on the A block....im assuming the b18a head doesnt have a coolant sensor on it like the b18b's do.
beyondstock
Mar 5, 2009 08:37 AM
latinf86
Sep 5, 2006 02:04 AM
Tammy_EP3
Oct 16, 2003 02:12 PM
racecarpete
Nov 24, 2002 04:44 PM
racecarpete
Nov 24, 2002 04:10 PM
