Removed a turbo kit: what to do with oil feed source?
The turbo is off my car but the place where the oil feed line screwed in, behind the block, how can I cap that off so oil wont come out? I dont have the stock part that goes there, what have others done to plug that hole?
Re: Removed a turbo kit: what to do with oil feed source? (non-turbo2dr)
I assume you lost the oil sender unit and you just have the feed line off of the hole? Buy a 1/8" NPT plug for it.
Re: Removed a turbo kit: what to do with oil feed source? (Tetsuo)
just remove the fitting, and install the oil pressure sending unit
HT's Biggest Loser
Re: Removed a turbo kit: what to do with oil feed source? (Farnsrocket)
Re: Removed a turbo kit: what to do with oil feed source? (SIXTYdashONE)
haha, I didnt even realize this post got brought back up. I bought a oil pressure switch, I was just curious if there was any other way of doing it.
B R Fittings
12-02-2011 06:28 PM
MikeMAN
07-02-2002 09:25 PM
