afc hack
Old Nov 24, 2002 | 09:55 PM
wrXtian's Avatar
Default afc hack
sorry to bring up this topic again.. i searched for this but didn't come out too successful.. just curious if the afc hack can work w/ the stock integra injectors? i have a b18a on boost and i need some sort of fuel control because it is not running good at all.. i keep throwing a code 43.
Old Nov 24, 2002 | 10:24 PM
filetofit
Guest
Posts: n/a
Default Re: afc hack (xjdm94x)
No, not with stock injectors. Code 43 is a fuel code, you got an inline pump? I assume you are running an FMU? My Haynes manual says check the o2 sensor, fuel pressure, fuel pressure regulator, and for vacuum leaks.
Old Nov 24, 2002 | 10:33 PM
wrXtian's Avatar
Default Re: afc hack (filetofit)
yeah i have a msd inline fuel pump.. and a vortech fmu set to 12:1..
Old Nov 24, 2002 | 10:40 PM
filetofit
Guest
Posts: n/a
Maybe you'r running way too rich. How much boost? I've never run an FMU but it seems people prefer the driveability of the hack. Pick up some DSM 450s for $50-$80 and you'll be on your way.
Old Nov 25, 2002 | 12:34 AM
wrXtian's Avatar
yeah i'm pretty positive i'm running way too rich.. my exhaust only smells like fuel haha.. hmm is there anything i can do in the timebeing.. i don't really have all the cash from injectors and a safc.
thanks
Old Nov 25, 2002 | 03:01 AM
sleepinEP3's Avatar
thanks
turn the boost down
Old Nov 25, 2002 | 12:02 PM
wrXtian's Avatar
Default Re: afc hack (sleepinEF2)
hmm.. i'm only running 5.5 psi.. i didn't htink that was that much..
Old Nov 25, 2002 | 12:04 PM
Mase's Avatar
pull your plugs, check them and see if you are infact running too rich
Old Nov 25, 2002 | 12:06 PM
Smashback's Avatar
Don't know what that code is, but are you running check valves or a missing link.
Old Nov 25, 2002 | 12:26 PM
filetofit
Guest
Posts: n/a
Lower your baseline fuel pressure or get a lower rate FMU like 8:1
Old Nov 25, 2002 | 12:54 PM
wrXtian's Avatar
yeah i'm running check valves.. i'm actually going to be picking up a SAFC sometime this up coming week.. what color are the plugs again if you are running rich or lean?
thanks
Old Nov 25, 2002 | 12:59 PM
Smashback's Avatar
Rich plugs are black and lean is white and spleckly. Stoich would be clean.
Old Nov 29, 2002 | 10:41 PM
fastludeh22's Avatar
Default Re: afc hack (Hatchblack)
if your running rich, turn the boost up.
Kp_VtekNiks
Sep 26, 2003 11:36 PM
SIK IN DA HED
Oct 2, 2002 08:41 PM
pelotudo
Sep 14, 2002 12:35 PM
FBP Ex-T
Feb 16, 2002 04:39 PM
newsense
Jul 6, 2001 11:37 AM
