techedge and ems?
Old Nov 23, 2002 | 10:24 PM
prophet's Avatar
Default techedge and ems?
i've seen a bunch of people use it but how do i actually wire it up to the ems? I'm thinking I'd just have to find what wire is the o2 sensor on my honda harness, cut it and and pretty much splice it into there, but on the techedge cable which one is the signal wire that i'd splice onto the plug with? Also is there anything else I'd have to wire up other than the ground, power, and signal to the EMS?
I'm figuring the signal wire would be the one that changes voltage (between 0-5 volts) so can i just use a volt meter? Or does anyone know exactly what colored wire it is from the tech edge cable?
Old Nov 23, 2002 | 10:42 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: techedge and ems? (prophet)
I dont remember what color the wire was, but if you get a meter you can measure the voltage.
SuperDuude
Jul 17, 2004 04:25 PM
streetstylenperformance
Feb 26, 2004 03:28 PM
5STAR3
Jan 22, 2004 03:47 PM
nsxmatt
Aug 7, 2002 07:20 PM
