iat grommet
Old Nov 23, 2002 | 05:01 PM
boosting's Avatar
Default iat grommet
my iat has been dangling for a while now and i want to drill a hole in the charge pipe and put it there, but from what i have read i will need a rubber grommet to insure no leaks and to keep it from blowing out under boost. so does anyone know where i could get a grommet that would be sufficient? online if possible.
Old Nov 23, 2002 | 06:07 PM
boosting's Avatar
Default Re: iat grommet (boosting)
will either of these work?
http://store.summitracing.com/partdetail.asp?part=31748
http://store.summitracing.com/partdetail.asp?part=21381
Old Nov 23, 2002 | 07:02 PM
Daniel's Avatar
You're better off putting the IAT sensor in the intake piping going to the turbo. it's meant to read ambient or near-ambient air temp., not compressed hot air. I cut a slit in the rubber connector that attaches the filter to the intake piping. The rubber kind of acts like a grommet except that it also keeps the filter from falling off.
here's what mine looks like:
[Modified by Daniel, 4:03 AM 11/24/2002]
Old Nov 23, 2002 | 07:08 PM
tony1's Avatar
Default Re: iat grommet (Daniel)
Actually, it's meant to read the temp of the air going into the motor. Whether it's hot or cold isn't relevant to where it should be placed as it is used to determine how much fuel enrichment you need. It will work better on the charge pipe.
Old Nov 23, 2002 | 07:11 PM
boosting's Avatar
Default Re: iat grommet (tony1)
will there be any performance drawback using 1 method over the other? or does it not really matter?
[Modified by boosting, 4:18 AM 11/24/2002]
Old Nov 23, 2002 | 07:18 PM
tony1's Avatar
It depends how effecient your ic is. If the air temp going into the motor is about the same as the underhood temp. then it won't matter. If you don't have an ic then it will matter. Maybe not a night and day difference, but if you're gonna do it you might as well do it the right way.
Old Nov 23, 2002 | 07:34 PM
boosting's Avatar
so you think if i drill a hole like 6'' before the intake manifold, i could just high temp silicone the sensor in there?
Old Nov 23, 2002 | 07:42 PM
Smashback's Avatar
No it won't hold. What I was thinking of doing was weldind like a 1" long tube the same diameter as the IAT sensor on the charge pipe near the TB, then attaching the IAT to the tube using rubber or silicone hose and a couple of hose clamps.
Old Nov 23, 2002 | 07:52 PM
tony1's Avatar
Default Re: iat grommet (Hatchblack)
I'm impressed, that's exactly how i did it on the 01 civic turbo I did. I angled the tube so that the sensor would have the air forced into the tube. It worked very good. We were watching air temps on the dyno with the obd2 scanner and they were reading about right.
Old Nov 23, 2002 | 08:21 PM
Daniel's Avatar
good ****.
But from all the D-series turbo owners i've talked to, they told me it'd be better to relocate the IAT sensor from the charge piping to the turbo intake, which I did. When it was in my charge piping, i'd get a CEL 03 everytime i hit VTEC while under full boost. now that I've moved it to the rubber connector, car runs better and no more CEL 03. so i don't know what happened there.
but thanks for clarifying the IAT sensor's job.
Old Nov 23, 2002 | 11:09 PM
accordfreak's Avatar
what kind of BOV is that?
landon.alder
Sep 10, 2009 09:30 PM
Turbo Dan
Aug 2, 2006 05:48 AM
89crxsleeper
Nov 26, 2005 08:19 PM
cbmprelude
Mar 23, 2004 11:34 AM
b16 matt
Mar 28, 2003 02:40 PM
