Help with Boost problems
Old Nov 24, 2002 | 10:03 AM
SiSoul's Avatar
Default Help with Boost problems
So after the motor rebuild nothing was changed only internals to je 9:9:1 and Eagle rods. The greddy kit was the same except for the FMIC and now I have a bogging problem at only full throttle. It almost feels like its cutting in and out all the time at full throttle. I think I have a fuel delivery problem and maybe running lean, is this the cause of my bogging at full throttle only? Help please?
Old Nov 26, 2002 | 10:39 AM
98TurboRS's Avatar
Default Re: Help with Boost problems (SiSoul)
Did you ever find out what was causing this? I have the same problem and it is very frustrating. I also have a greddy kit w/ IC. It runs fine under partial throttle but cuts out at full throttle..almost bucking.
Old Nov 26, 2002 | 10:55 AM
SiSoul's Avatar
Default Re: Help with Boost problems (98TurboRS)
NO I havent found out yet. Feels kinda funny, like there is not enough fuel or something. Do you have any check engine lights? I need to take it to a shop to look at it. I was just wondering if anyone online would know.
Old Nov 26, 2002 | 11:33 AM
Mikeyslude's Avatar
are you getting enough fuel?
Old Nov 26, 2002 | 11:49 AM
FredoSP's Avatar
Hmm almost like the car "berps"? Id say do a compression check and get in the Dyno and see your A/F ratio. Ive gotten CEL 72 73 74 Misfire in cyc 2 3 4, but shes seems fine so I dunno. I feel like a burp or a thumb when I'm in 5th gear in VAC, its odd to explain.
FYI: 18G Greddy Kit, no other upgrades internally or timing, 93 octane gas and Blue Box. I think it might be a timing issue but I'll know once I have Hondata in soon.
Old Nov 26, 2002 | 01:36 PM
b16ahybrid's Avatar
Default Re: Help with Boost problems (FredoSP)
pull your plugs they will tell you if your leaning out or not.......
Offer
Sep 9, 2006 07:10 PM
turboteg2nv
Nov 28, 2005 10:29 PM
mrx
Jan 18, 2005 11:48 PM
mrx
Jul 11, 2004 04:26 AM
zseeanz
Nov 23, 2003 08:55 AM
