skipping problems....turbo experts inside.....
Old Nov 25, 2002 | 08:14 PM
DD_JonnyLee's Avatar
Default skipping problems....turbo experts inside.....
ever since i put my drag gen 3 on ive had a very bad popping sound above 7000 and when it starts to pop the car falls on its face, ive had people tell me that the flame was being blown out of the plug , so i changed them to a new set of the cold ones that import parts recommends and gapped them at 32 and it still does it, it is the 7 lb kit that i purchased from import parts, and when the popping occurs, the boost gauge jumps to 15lbs and my a/f ratio gauge reads lean, i have called Import Parts numerous times and all i get is mike, and he tells me i need to talk to ben , and he is never there , so i emailed him and he told me that all i could do was find someone near me and borrow there wastegate and see if that was the problem, sorry about rambling but i need this problem resolved before i blow my motor, oh by the way its a 00 gsr
if anyone could give me help i would really appreciate it,
thanks
jonathan
again sorry for rambling
Old Nov 25, 2002 | 08:23 PM
Tofurky's Avatar
Default Re: skipping problems....turbo experts inside..... (JonathanH)
you sure you didn't already blow it?
Old Nov 25, 2002 | 08:29 PM
Default Re: skipping problems....turbo experts inside..... (Ruckus138)
yes im sure i didnt already blow it, it doesnt smoke a bit ,it idles fine, has good vacuum , it only skips up top
jonathan
Old Nov 25, 2002 | 08:52 PM
ttt
Old Nov 25, 2002 | 08:55 PM
paulzy's Avatar
popping up in higher RPMs can also mean that you're running lean
I suggest you get it on a Dyno
Old Nov 25, 2002 | 08:57 PM
brian b's Avatar
New User
yeah if its spiking you need to look at your vac lines and wastegate.. the car is probably popping due to detonation from twice the amount of boost that you have fuel available for
1sikhatch
Dec 14, 2009 01:56 AM
Jo$e L@go
Apr 21, 2009 07:14 PM
D15Bbigred
Mar 20, 2006 09:12 AM
icantthinkofaname
Nov 4, 2003 01:24 PM
JSpecwest
Sep 3, 2001 01:25 PM
