wastegate order question
Old Nov 2, 2003 | 02:52 PM
redboost10's Avatar
Default wastegate order question
when a tial wastegate is ordered from cheapturbo.com does it come with a spring or is it an extra cost?
Old Nov 2, 2003 | 03:34 PM
Ben Huynh's Avatar
Default Re: wastegate order question (tgh99si)
All Tial wastegates come with the spring.
Old Nov 2, 2003 | 04:39 PM
redboost10's Avatar
Default Re: wastegate order question (ben@importparts.com)
whats the max psi for the .5 bar(7.25 psi)? the least i can run is 7.25 psi and then whats like the most psi i can run before i gotta get a bigger one?
Old Nov 2, 2003 | 05:16 PM
redboost10's Avatar
ill try to be more clearer, on a .5 bar(7.25 psi) i have to run at least 7.25 psi. i was wondering whats the most psi i am able to run before i have to get a bigger spring for more boost?
Old Nov 2, 2003 | 05:40 PM
bluebullet's Avatar
you can use a boost controller to go up from there. You should not need to replace the spring unless you want to bump up the minimum boost.
lilintegra25
Jan 23, 2007 08:52 PM
95srv
May 12, 2006 07:09 AM
2LiterTurboSeR
Aug 25, 2005 11:04 PM
zbower7
Feb 6, 2004 09:48 AM
Spoold_R
May 12, 2003 06:21 PM
