can i use the ge ls/vtec supply sender that goes on the oil filter for my turbo line
just wondering if anyone uses the oil sender from ge instead of tapping a line where the oil pressure sensor is?
Re: can i use the ge ls/vtec supply sender that goes on the oil filter for my turbo line (crx1856)
ypu, they are made for either the ls/vtec or a turbo supply.
Re: can i use the ge ls/vtec supply sender that goes on the oil filter for my turbo line (Foozball26
Yes you can, and it is an excellent solution, don't have to worry about finding one of those BSPT pieces to tap the block, and then t off you oil sender to the firewall.
And I hear the ladies find it completely irrestible when they kow you'vre run your oil lines this way.
Did I mention I'm selling one?
https://honda-tech.com/zerothread?id=537721
-PHiZ
-PHiZ
I use one of the GE oil "vtec" things on my block. Its great because the oil to your turbo is FILTERED oil, so you get nice clean oil going to your turbo. Help keep your turbo safe for years to come. Its a great investment!!
liam
