Piston rings gone?
Old Oct 30, 2003 | 08:49 PM
ITSTOCK's Avatar
Default Piston rings gone?
My buddy has a turbo integra, and at idle, it blows oil out of teh breather on teh valve cover. he checked compression and #1 was 90psi #2 165psi #3 170psi #4 85psi. BUT, the car still feel like it has all the power it had before it started smoking. We did the compression test with teh dist. and injtecors in, i wa stold to get 100% accurate readings to take teh dist. off and the injectors. Anyway, does it sound like the rings are gone, even though it stil has just as much power?
Old Oct 30, 2003 | 08:57 PM
roydogg's Avatar
Default Re: Piston rings gone? (ITSTOCK)
Dam right it's time for a rebuild or just keep beating on it and see what happens. Cylinders 1 and 4 Ringlands are fucked.
Old Oct 30, 2003 | 09:06 PM
T-sohctec's Avatar
Default Re: Piston rings gone? (roydogg)
What he said.
Old Oct 30, 2003 | 09:29 PM
TurboTegB18c's Avatar
Default Re: Piston rings gone? (T-sohctec)
Sounds like piston rings are gone. The longer u drive it, the more chances of tearing things up.
Old Oct 30, 2003 | 09:31 PM
11psiTurboSI's Avatar
Default Re: Piston rings gone? (TurboTegB18c)
I got my money on ringlands... same thing happen to me
Old Oct 30, 2003 | 11:13 PM
phase12gsr's Avatar
Default Re: Piston rings gone? (9psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9psiTurboSI &raquo;</TD></TR><TR><TD CLASS="quote">I got my money on ringlands... same thing happen to me </TD></TR></TABLE>
yep, same thing happened to me too. damn turbo gsrs
Old Nov 1, 2003 | 05:29 AM
ITSTOCK's Avatar
Default Re: Piston rings gone? (phase12gsr)
stock motors suck, time for soem rebuilds, or better motors
Old Nov 1, 2003 | 07:36 AM
earl's Avatar
That would my guess also. You need a good stand alone to control fuel management problems.
Old Nov 1, 2003 | 07:39 AM
Ri5e's Avatar
Broken Ring Lands.
GTEater
Sep 30, 2010 09:43 PM
silverboost
Nov 8, 2005 01:01 PM
IGOTpinkShards
May 28, 2004 10:48 PM
done
Apr 23, 2004 06:55 PM
S2KP
Oct 24, 2003 03:39 AM
