Stahl's at stop
Old Oct 31, 2003 | 09:07 AM
BDTURBO's Avatar
Default Stahl's at stop
I have a 95 civic with Greddy turbo, my car idles low then turns off at a stop...sparatically not everytime or even everyday. If I turn my AC on the extra belt raises my RPM's and my car will stay on. Any ideas what it could be. Thanks guys.
Old Nov 3, 2003 | 09:11 AM
BDTURBO's Avatar
Default Re: Stahl's at stop (BDTURBO)
no one person has a clue, come on guys!
Old Nov 3, 2003 | 09:36 AM
Bailhatch's Avatar
could be lots of things. cloged cat or air filter maybe
Old Nov 3, 2003 | 05:32 PM
Mista Bone's Avatar
D Tranny Guru
Stahl's went out of business??????
http://www.stahlheaders.com/
I hope not, I need custom bent tubing!!!!!!!
Old Nov 3, 2003 | 05:39 PM
9200RPM's Avatar
Default Re: Stahl's at stop (Mista Bone)
AHH HAAA
Old Nov 3, 2003 | 06:27 PM
scttydb411's Avatar
mine did that after i installed my turbo w/ afc hack. i just readjusted my throttle cable and idle and all was fine.
Old Nov 6, 2003 | 07:36 AM
BDTURBO's Avatar
Default Re: Stahl's at stop (scttydb411)
isn't your idle computerized....so if I adjust my cable my computer will try to compensate for that and mess it all up correct or not?
Old Nov 6, 2003 | 12:44 PM
diputs's Avatar
I've got greddy turbo and I was having an idle problem where it would try to idle at 300-400 rpm. I had to drive with my headlights on to bump my idle up. It was an easy fix for me. I just screwed the bypass screw on the TB out 3/4 of a turn. I think it lets more air past the TB so the IACV doesn't have to work so hard when I come off throttle to modulate idle. My problem was mainly when I was coming off-throttle, or if I blipped the throttle after my car was fully warmed up the idle would drop way low and stay there for a second until the ecu idled it back up. Hope that helps.
Arthas
Mar 14, 2010 09:08 PM
Car Tweaker
Sep 13, 2009 08:28 PM
jdm4drSi
Apr 6, 2007 08:19 AM
headhunter
Aug 18, 2003 08:14 PM
chirp2hrd
Oct 13, 2002 01:36 AM
