Explaining Specs of a Turbo
Old Oct 29, 2003 | 03:06 PM
DrkGreenAccord's Avatar
Default Explaining Specs of a Turbo
I have been learning about turbos for months now and every once in a while technical jargon such as a/r, inducer, 60-1 and all these specs arise. Can someone explain what do they mean so I can determine and understand what's best for me?
I know the basics, but the technical stuff goes way over my head.
Old Oct 29, 2003 | 03:09 PM
DA-MAX's Avatar
Default Re: Explaining Specs of a Turbo (DrkGreenAccord)
heres a nice thread to start with.....
https://honda-tech.com/zerothread?id=142398
Ri5e's Avatar
A/R is the size of the housing. It's just a measure of the cross sectional area of the outlet over the radius (Center of the turbo to the outlet).
If you open up a turbo, the wheel will have blades. The outter most diameter of the blades is the exducer and the innermost is the inducer.
Trim is just the ((Inducer/Exducer) ^2 ) * 100
Old Oct 29, 2003 | 03:20 PM
TeStUdO's Avatar
Default Re: Explaining Specs of a Turbo (DA-MAX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">heres a nice thread to start with.....
https://honda-tech.com/zerothread?id=142398</TD></TR></TABLE>
Thats a good one for Compressor Maps, here's one for what you need with pretty illustrations https://honda-tech.com/zerothread?id=153810
Old Oct 29, 2003 | 03:23 PM
DA-MAX's Avatar
Default Re: Explaining Specs of a Turbo (TeStUdO)
heh thats the one I was looking for
Old Oct 29, 2003 | 03:24 PM
TeStUdO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA-MAX &raquo;</TD></TR><TR><TD CLASS="quote">heh thats the one I was looking for </TD></TR></TABLE>
Well maybe you should bookmark it then like I did
Good to see a fellow person from The Old Line State
Old Oct 29, 2003 | 03:25 PM
Thanks
Old Oct 29, 2003 | 03:28 PM
DA-MAX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO &raquo;</TD></TR><TR><TD CLASS="quote">
Good to see a fellow person from The Old Line State</TD></TR></TABLE>
I see your s/n name is testudo....do you go to UMD by chance??
Pete_SI
Aug 15, 2005 02:55 PM
bluedelsol
Jun 11, 2003 03:37 PM
viprcr1
Jan 31, 2003 04:55 PM
