Jackson Racing Supercharger - boost gauge install help
ok heres the problem guys!
i got a 98 dx hatch and i got a jrsc in her but now i wanna run a gauge boost. ive connected it to my intake manifold using a vacuum line, and i get a negative boost reading (vacuum) even under load and movement im only getting to a reading of 0psi, wat am i doing wrong?? thanx guys
Re: Jackson Racing Supercharger - boost gauge install help (beaterdx)
You say you have it hooked up to your intake..but are you sure you don't have it hooked up to you throttle body?...if so that would explain it..the guage needs to see boost..so you would need to hook it up after the blower.
just check to make sure
Jon
Jon
Are you sure you are getting into boost?...do you have any pics?
on my JRSC mani I had about 2-3 ports for vacumn/boost..it was just above the blower. I am assuming you are usuing one of those right?
Jon
Jon
Re: Jackson Racing Supercharger - boost gauge install help (Jonny Black)
could i be loosing boost somewhere?? im gunna clamp all my hoses down...and re check em...
as for pics...soon
as for pics...soon
yes im using a nipple on the top of the blower itself, right beside the JR fuel pressure reg theres a lil nipple i can tap into. im usin that
