wastegate spring question ( i searched for it "wastgate spring)
when im picking out a spring is for example a 7.25 psi bar, is the the least or most i can run. i forgot whhat it was. please help me out.
Re: wastegate spring question (B18c1Turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18c1Turbo »</TD></TR><TR><TD CLASS="quote">and if you get a spring with a boost controller? how would that work?</TD></TR></TABLE>
I'd like to know too. If i got a boost controller would I need to change the springs or would i even need a spring to boost from 6-12 psi?
Re: wastegate spring question (EG(6)SR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG(6)SR »</TD></TR><TR><TD CLASS="quote">
I'd like to know too. If i got a boost controller would I need to change the springs or would i even need a spring to boost from 6-12 psi?</TD></TR></TABLE>
The spring size will regulate your minimum boost pressure. The boost controller will be used to increase and decrease boost pressure (not lower than what's regulated by the spring).
