removing Inline pump, will it mess up tunning?
Old Oct 30, 2003 | 12:00 AM
R-1303's Avatar
Default removing Inline pump, will it mess up tunning?
I'm going to remove my inline pump that came with the drag kit for my b18c5 and going to install an walboro 255 intank....will this through off the tunning??..once the walboro is on, I plan to drive straight to the dyno.
Thanks, mark
Old Oct 30, 2003 | 07:57 AM
Muckman's Avatar
Moderator in Chief
Default Re: removing Inline pump, will it mess up tunning? (R-1303)
only if the fuel pressure changes. if you have a way to change the base pressure to the same pressure it was tuned on, everything else should line up.
Old Oct 30, 2003 | 08:56 AM
4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by R-1303 &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to remove my inline pump that came with the drag kit for my b18c5 and going to install an walboro 255 intank....will this through off the tunning??..once the walboro is on, I plan to drive straight to the dyno.
Thanks, mark</TD></TR></TABLE>
Are you running FMU or AFC hack...? If so, then once on the dyno it should be fine, but I wouldn't boost without that inline until you tune and are sure everything is safe...
Old Oct 30, 2003 | 10:57 AM
R-1303's Avatar
Default Re: removing Inline pump, will it mess up tunning? (4U2NV)
I'm currently running the inline fuel pump (between fuel filter and fuel rail) that came with the drag kit..I plan on getting the ss fuel lines so the inline pump will be replaced by an warlboro in-tank. My fuel setup is hondata s200 with 440's....just wondering if it would be safe to if i removed the inline and put in the walboro and drive it to the dyno....or would the fuel pressure be unsafe??
Old Oct 30, 2003 | 02:10 PM
drvfast's Avatar
you will be fine just don't boost
Old Oct 30, 2003 | 03:26 PM
baphomet's Avatar
Default Re: removing Inline pump, will it mess up tunning? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">only if the fuel pressure changes. if you have a way to change the base pressure to the same pressure it was tuned on, everything else should line up.</TD></TR></TABLE>
Old Nov 18, 2003 | 11:19 PM
R-1303's Avatar
so your saying..if i don't mess with my fuel pressure regulator..(which i don't have one) it should be o.k to drive to the dyno??
Old Nov 18, 2003 | 11:25 PM
rjardy's Avatar
so your saying..if i don't mess with my fuel pressure regulator..(which i don't have one) it should be o.k to drive to the dyno??</TD></TR></TABLE>
You have a fuel pressure regulator.
Rob
Old Nov 19, 2003 | 12:42 PM
R-1303's Avatar
Default Re: removing Inline pump, will it mess up tunning? (rjardy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjardy &raquo;</TD></TR><TR><TD CLASS="quote">
Rob</TD></TR></TABLE>
o.k...a stock one..but can i drive down to the dyno?? (safely)
Old Nov 19, 2003 | 12:49 PM
01ITR#700's Avatar
o.k...a stock one..but can i drive down to the dyno?? (safely)</TD></TR></TABLE>
Yes, you'll be perfectly safe to drive it to the dyno.
M
Old Nov 19, 2003 | 07:32 PM
R-1303's Avatar
Default Re: removing Inline pump, will it mess up tunning? (01ITR#700)
ok..since i could drive down to the dyno..you think it will be o.k to boost??
sorry for so many questions..just worried about my motor.
Old Nov 19, 2003 | 08:45 PM
ndogg's Avatar
if your worried about it. DON"T boost.
Old Nov 19, 2003 | 09:39 PM
R-1303's Avatar
Default Re: removing Inline pump, will it mess up tunning? (ndogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ndogg &raquo;</TD></TR><TR><TD CLASS="quote">if your worried about it. DON"T boost.</TD></TR></TABLE>
ummm..o.k?!?! I was wondering if it would be safe...so i could drive normally down to the dyno.
Old Nov 19, 2003 | 09:47 PM
SIK IN DA HED's Avatar
New User
its quite simple...
DONT BOOST = dont hit the gas at WOT while enjoying the whistling sounds your turbo is making.
otherwise, youll hear the sound of your cel phone as you dial for someone to tow your car because you had just blown your engine.
Old Nov 20, 2003 | 05:57 AM
ndogg's Avatar
ummm..o.k?!?! I was wondering if it would be safe...so i could drive normally down to the dyno.</TD></TR></TABLE>
dont go throwing hammers at anyone you please. its a good way to **** people off.
sway892
May 17, 2004 04:35 PM
bottlefedb18c1
Aug 1, 2002 09:35 AM
R-1303
Jul 11, 2002 04:15 PM
CM-R
Jun 21, 2002 11:34 AM
Dravis
Sep 18, 2001 07:40 PM
