Smaller radiator for turbo space?
Old Nov 1, 2003 | 03:55 PM
Coupe-R's Avatar
Default Smaller radiator for turbo space?
HI i am turboing a da6 integra
they have a large radiator in the front and i have seen that vtec civics have a smaller radiator.
so i do not have to cut into the side of my car for pipes, can i run a smaller civic radiator to give me all that space for IC piping or will this make the car overheat
after all the cars run the same engines b16a2's so why is my one bigger?
Old Nov 1, 2003 | 03:59 PM
pornstarSR's Avatar
Default Re: Smaller radiator for turbo space? (Redinteg)
im not sure if the body of that code, but i do know that DC integra's can run EK civic radiators and EK civic can run DC radiator.
not sure if you swap mouting hardware also but i think you do...
hopefully this helps
Modified by pornstarSR at 1:09 AM 11/2/2003
Old Nov 1, 2003 | 04:08 PM
LiLOtaku's Avatar
I don't know how much space you have in front of your radiator on your car, but You might possibly be able to get a slim-fan from pep boys and install it in front of your radiator and remove your stock radiator fan.
Its what I did to increase space in that area on my civic, i just took out the condenser fan, and re-located a slim fan in front of it.
Old Nov 1, 2003 | 09:21 PM
Coupe-R's Avatar
Default Re: Smaller radiator for turbo space? (LiLOtaku)
ok i put it easier
can a 92 G2 Integra 1600 vtec Run a 92 Civic 1600 vtec radiator with turbo for increased space
or will it get too hot cause the radiator is smaller on those
Old Nov 2, 2003 | 01:09 AM
Foozball26's Avatar
the civic style radiator is fine, mounting is a different subject.
how many civics do you see running around with gsr swaps and such with thier style radiator...alot, so it can be done. You mind as well get an aftermarket radiator whille your swapping it out.
Old Nov 2, 2003 | 04:22 AM
Coupe-R's Avatar
Default Re: Smaller radiator for turbo space? (Foozball26)
yea but civics with gsr swaps that means going bigger
I live in New Zealand is a GSR a B18C teg right with a bigger radiator than a civic
i am talking going smaller not bigger
Old Nov 2, 2003 | 07:21 AM
Tinker219's Avatar
itll cool the engine adequately enough(mine did fine on my 12 psi H22), but your problem will be mounting. If you can make a few brackets, it can easily be done. If you are scared of some brackets, than might want to look into something else...
Old Nov 2, 2003 | 07:26 AM
Foozball26's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redinteg &raquo;</TD></TR><TR><TD CLASS="quote">yea but civics with gsr swaps that means going bigger
i am talking going smaller not bigger</TD></TR></TABLE>
Yes the integras have a larger radiator, but civics that swap a gsr motor in cool fine wiht their stock radiator.
Old Nov 2, 2003 | 07:31 AM
g2turbo's Avatar
i had a drag 3 kit on my 92 integra and i put a half size fluidyne in there for more room. The car would absolutely not stay cool. Maybe my fan wasnt adequate though cause many people have used this same radiator with good results.
Im redoing my car currently and im planning on using a full radiator again. CHRIS
Old Nov 2, 2003 | 09:08 AM
Flamenco-T's Avatar
Default Re: Smaller radiator for turbo space? (g2turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">i had a drag 3 kit on my 92 integra and i put a half size fluidyne in there for more room. The car would absolutely not stay cool. Maybe my fan wasnt adequate though cause many people have used this same radiator with good results.
Im redoing my car currently and im planning on using a full radiator again. CHRIS</TD></TR></TABLE>
did you bleed all the air out of your system ? how did you do it ?
stan
Old Nov 2, 2003 | 09:32 AM
g2turbo's Avatar
Default Re: Smaller radiator for turbo space? (Flamenco-T)
yes i bled the system. that was not the problem. I am guessing the problem was that my fan wasnt pulling enough cfm/. All i know is that soon as i switched to the full size the car didnt even turn the fans on unless i was in traffic. it worked very well. CHRIS
Old Nov 2, 2003 | 01:32 PM
Coupe-R's Avatar
ok so how do all the G2 teg guys do it
i want pics and stuff of how u mount ur turbo pipes
what cutting u do ect
i am thinking one pipe can go up through where the intake resinator used to be
Old Nov 2, 2003 | 02:12 PM
Rah Rah's Avatar
I had the same setup on my DA, a Del Sol vtec radiator. I had it rigged ghetto style though. I was holding the top part down with a wire and the bottom had one leg in the passenger side bracket and the other leg in the air. The problem is that you'll have to fabricate your own mounting brackets. The big fat crossmember also doesn't give you much room. You wont have a cooling problem it's just that it's not exactly a bolt-on affair. As far as my piping, I removed the driver side tow hitch and snacked the tubing through that small crack. DA's have no room whatsoever. My advice is to buy an aftermarket crossmember. It will give you more room to work with. I think Place Racing makes one for DA's.
Old Nov 2, 2003 | 02:17 PM
GS-Rcivic's Avatar
Default Re: Smaller radiator for turbo space? (Rah Rah)
im runing a dual core radiator with a gsr swap on my hatch, cools better than before. Needle does not even pass the half way mark even after going 100mph all the way down to carlisle, PA.
Old Nov 2, 2003 | 11:44 PM
Coupe-R's Avatar
Default Re: Smaller radiator for turbo space? (GS-Rcivic)
u don't need to go close to the cross member though, that means droppin the pipes below the cross member
not good for me cause i will scrape em
can someone show me pics of there G2 turbo setup up close how the rigged the pipes up
Old Nov 3, 2003 | 12:42 AM
jeremyG2teg's Avatar
You have the right idea going for the routing of the IC piping on the passenger side. Your options on the drivers side are soley dependent on how many creature comforts you are willing to sacrifice. Here are a few pics of a couple of different configurations that I have done.
Old Nov 4, 2003 | 02:16 AM
Coupe-R's Avatar
Default Re: Smaller radiator for turbo space? (jeremyG2teg)
OOps i forgot to say my car is right hand drive so things are a lil different
hehe, cheers for da pics
Old Nov 4, 2003 | 07:06 AM
Stu's Avatar
Stu
New User
Go to http://www.g2ic.com
Old Nov 4, 2003 | 08:13 AM
Ri5e's Avatar
Default Re: Smaller radiator for turbo space? (Stu)
What's with that Dr. Pepper can in one of the pics?
Old Nov 4, 2003 | 01:03 PM
Default Re: Smaller radiator for turbo space? (CRV Monster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRV Monster &raquo;</TD></TR><TR><TD CLASS="quote">What's with that Dr. Pepper can in one of the pics?</TD></TR></TABLE>
I no longer have power steering so the soda can plays the role of the breather/reservoir.
More info about this can be found here... https://honda-tech.com/zerothread?id=184202&page=3
Old Nov 4, 2003 | 01:15 PM
Stu's Avatar
Stu
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jeremyG2teg &raquo;</TD></TR><TR><TD CLASS="quote">
More info about this can be found here... https://honda-tech.com/zerothread?id=184202&page=3</TD></TR></TABLE>
Just take out your power rack and put a manual rack in, then you won't even have to deal with that at all, and you'll be lighter anyway!
Old Nov 4, 2003 | 01:20 PM
Armed Ferret's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stu &raquo;</TD></TR><TR><TD CLASS="quote">
Just take out your power rack and put a manual rack in, then you won't even have to deal with that at all, and you'll be lighter anyway! </TD></TR></TABLE>
yep.....and the steering ratio is worse. trust me, i put in a manual rack.....and i'm putting the p/s rack back in with the breather setup.
Old Nov 4, 2003 | 01:29 PM
Default Re: Smaller radiator for turbo space? (G2 Pilot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G2 Pilot &raquo;</TD></TR><TR><TD CLASS="quote">
yep.....and the steering ratio is worse. trust me, i put in a manual rack.....and i'm putting the p/s rack back in with the breather setup.</TD></TR></TABLE>
ding ding ding
Besides, this was a much easier solution then swapping the enitre rack.
Old Nov 6, 2003 | 02:17 AM
Coupe-R's Avatar
ok alot of people are saying i won't need to cut anything
and i can do it with the normal radiator ect
i hope this is the case
eightvalver
Sep 22, 2007 01:17 PM
TRM04
Jan 6, 2003 11:29 AM
