Hondata and Smog???
Old Oct 31, 2003 | 05:48 PM
Thrillhouse's Avatar
Default Hondata and Smog???
Will my car pass smog if I am running a greddy kit @6psi, with Hondata s200b, 550cc injectors? Don't you have to change the ecu for hondata? Won't this cause me to not pass smog?
Old Oct 31, 2003 | 07:19 PM
HXMan's Avatar
Default Re: Hondata and Smog??? (Thrillhouse)
If your car is OBD2 no you won't pass.
Not sure if your car is OBD1.
Old Oct 31, 2003 | 09:15 PM
rjardy's Avatar
where do you live?
Rob
Old Nov 1, 2003 | 06:28 AM
Default Re: Hondata and Smog??? (rjardy)
I live in sunny southern california! I am starting to hate it here.
Old Nov 7, 2003 | 06:29 AM
T3T495GSR's Avatar
i was wondering the same thing kinda. my car is a 95 gsr and im running drag 3 turbo kit , but when i get it smogged i use the cat, i disconnect the IC pipe so i see no boost and i detune the afc to zero for stock settings. i keep failing the hydrocarbons. if i got hondata or uberdata (debating on which to get) can i get it to pass smog by tuning it for less hydrocarbons (unburnt fuel) also, im using the 255lph fuel pump, i think that might of made me fail.
thanks
DUSTIN
Old Nov 7, 2003 | 06:32 AM
wickedEFguy's Avatar
Default Re: Hondata and Smog??? (T3T495GSR)
do you have a FPR or your stock injectors? If you do then I'd turn your Fuel pressure down way low or replace your injectors with your stock ones and try again
jake00si
Mar 13, 2010 08:21 PM
racekar
Sep 7, 2005 01:57 PM
MrEG6er21
Feb 13, 2005 01:13 AM
an6e1o82
Nov 16, 2004 11:11 PM
tubedriver
Jan 21, 2003 09:58 AM
