NITROUS + D16
Old Oct 31, 2003 | 07:45 AM
nitrouspete's Avatar
Default NITROUS + D16
what do i need to make it possible.. well im gunna do it so what do i need to make it safe(as safe as i can get it)
i want it to run.. what cam do you sugest? im thinkin one of those lil zex cams, maybe give comp a call or something.. its an auto, dont worry though tci will be getting a call too (3000 stall baby )
any hoo thanks.. what do i need? besides the nitrous(kit and everything)
Old Oct 31, 2003 | 07:55 AM
baphomet's Avatar
Default Re: NITROUS + D16 (nitrouspete)
Do a compression test before you start.
1. new plugs ngk bkr7e?s
2. FPR
3. New clutch
4. Fuel pump
5. Motor mount inserts
Check your timing - pull ~2 degrees per 50 shot. I also suggest a window switch.
Summit Pricing and Part Number for Window Switch
#MSD-8956 RPM Window Activation Switch = $76.95
#MSD-8744 RPM Modules 4000-4800 = $20.69
#MSD-8748 RPM Modules 8000-8800 = $20.69
#MSD-8961 MSD High Current Relay DPST = $25.95 TOTAL = $148.28
Though you would prob need lower rpm pills.
Old Oct 31, 2003 | 10:53 AM
what fpr do you recamend?
thanx for the help guys..
Old Oct 31, 2003 | 10:56 AM
oh yeah.. its a brand new motor.. so i guess the compression is ok lol.. should i retard the cam gear any? i was thinking 1 or 2 deg. that way i wont have to rev it as high to get it in its power band and i wont have to use such a high rpm pill.. maybe im way wrong and that doesnt make since to you, but anyways im in a hurry so thanks
Old Oct 31, 2003 | 11:15 AM
baphomet's Avatar
Default Re: (nitrouspete)
I have a b&m - titan has them w/guage for 80 shipped - I wouldn't touch the cam gears unless your at a dyno. BTW, you can get pills for any rpm. Just search http://www.summitracing.com
Old Oct 31, 2003 | 12:48 PM
Finest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrouspete &raquo;</TD></TR><TR><TD CLASS="quote">what fpr do you recamend?
thanx for the help guys..</TD></TR></TABLE>
Stock?
You do know that with a dry kit, it will raise your fuel pressures to compensate for the nitrous?
But the basic necessities include:
1 step colder spark plugs
Retard IGNITION timing 1-3 degrees
Run 93+ octane ONLY when squeezing.
Open up your exhaust as much as possible.
Don't hit the rev limiter, and don't spray under 2k rpms.
Good luck!
Old Oct 31, 2003 | 01:10 PM
baphomet's Avatar
Default Re: (98CTRCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98CTRCoupe &raquo;</TD></TR><TR><TD CLASS="quote">
Umm yeah, he never said anything about what kit he had - though he said something about zex cam.
Old Oct 31, 2003 | 08:42 PM
PHiZ's Avatar
Default Re: (slashDEVslashNULL)
He DID however say that the car is an auto, so what would you have him do with that clutch?
-PHiZ
Old Oct 31, 2003 | 09:13 PM
9200RPM's Avatar
Default Re: NITROUS + D16 (slashDEVslashNULL)
Stock up on Exhaust valves...we have ate a few....all the same...on number 2 cylinder...
Old Nov 1, 2003 | 11:00 AM
yeah its an auto, and ill be useing the nitrous express wet kit, bottle warmer, purge, the works! so yall dont think ill need a afpr? iv already got colder plugs, and brand new motor mounts. what fuel pump do you recamend? the way its looking right now its either gunna be a cam or a stall.. so im pretty sure ill be calling tci! thanx alot guys
Old Nov 1, 2003 | 12:10 PM
baphomet's Avatar
Default Re: (PHiZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PHiZ &raquo;</TD></TR><TR><TD CLASS="quote">He DID however say that the car is an auto, so what would you have him do with that clutch?
-PHiZ</TD></TR></TABLE>
I was hinting at a manual tranny swap
Old Nov 1, 2003 | 02:58 PM
no manual swap.. im poor
Old Nov 1, 2003 | 04:28 PM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nitrouspete &raquo;</TD></TR><TR><TD CLASS="quote">no manual swap.. im poor</TD></TR></TABLE>
just joking...I was covering my tracks I have a walbro pump - I believe lightening has them for 99 shipped.
Old Nov 1, 2003 | 07:24 PM
Mista Bone's Avatar
D Tranny Guru
1. ZEX kit
2. Champion RC9YC4 plugs (thanks ZEX man!)
3. Walbro 255 HP fuel pump
4. 310-325 cc injectors
5. MSD 6AL (7800 limiter) and rechipped ECU (8500 limiter)
6. slicks and LSD
Old Nov 2, 2003 | 12:40 PM
RyanEJ8's Avatar
Stock?
Good luck! </TD></TR></TABLE>
An aftermarket FPR is still a good idea with a dry kit.
jnasty
Jan 30, 2007 06:28 PM
gookspeed
Mar 7, 2005 11:23 AM
Bleed Black
Oct 1, 2002 02:44 PM
teggygsr
May 5, 2002 07:46 AM
