Using ABS plastic pipes for compressor inlet to filter?
Old Oct 30, 2003 | 12:36 PM
incogNitto's Avatar
Default Using ABS plastic pipes for compressor inlet to filter?
I found some 90 degree ABS plastic pipes on this site, and it seems perfect to attach to the compressor inlet so I can put a filter on a 60-1. Am I looking for trouble using ABS plastic? I doubt it seeing as how a lot of people use dryer ducting. Opinions anyone?
http://www.extremausa.com/acce...yID=4
Old Oct 30, 2003 | 02:22 PM
InTeGrA B18b1's Avatar
Default Re: Using ABS plastic pipes for compressor inlet to filter? (incogNitto)
it will probaly melt
Old Oct 30, 2003 | 02:28 PM
lazerus's Avatar
Default Re: Using ABS plastic pipes for compressor inlet to filter? (InTeGrA B18b1)
mcmaster rates ABS at 160+ *F
...not sure if it will hold up to the heat
Old Oct 30, 2003 | 02:33 PM
falcongsr's Avatar
What is this crap?
Default Re: Using ABS plastic pipes for compressor inlet to filter? (lazerus)
you probably want at least 200f rating for anything underhood.
Old Oct 30, 2003 | 02:48 PM
99integralsturbo's Avatar
get silicone if you can
Old Oct 30, 2003 | 02:56 PM
tegasaurus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by incogNitto &raquo;</TD></TR><TR><TD CLASS="quote">I found some 90 degree ABS plastic pipes on this site, and it seems perfect to attach to the compressor inlet so I can put a filter on a 60-1. Am I looking for trouble using ABS plastic? I doubt it seeing as how a lot of people use dryer ducting. Opinions anyone?
http://www.extremausa.com/acce...yID=4 </TD></TR></TABLE>
hey, i found some aluminum on this site
http://www.jcwhitney.com/webap...Id=-1
Old Oct 30, 2003 | 03:04 PM
danl's Avatar
Banned
Default Re: Using ABS plastic pipes for compressor inlet to filter? (tegasaurus)
The fact that your running a 60-1 means you got some cash. Run stainless steel or alumiumn with silicone couplers. I run PVC and it holds up fine but looks ugly. Its gonna get replaced with 304 series 3"stainless steel soon.
Old Oct 30, 2003 | 05:23 PM
incogNitto's Avatar
I ordered some other bends from JC Whitney but I couldn't find any place with a 4" 90 degree elbow. Checked a couple of local muffler shops and they didn't have any 4" piping in stock.
Anyone know the best place to get a mandrel bent elbow as the silicone elbow probably wouldn't hold the weight of the filter on the end.
Edit:
Found a place http://www.tanklesswaterheaters.com/fasnseal.html
Looks like these could work if anyone else is looking for 4" piping.
Modified by incogNitto at 11:55 PM 10/30/2003
Midori Green
11
Apr 16, 2008 07:03 PM
You Know I Got SOL!
Sep 11, 2006 08:34 AM
george34
Jun 27, 2005 11:01 AM
Tommy_Gunns
May 20, 2003 11:18 AM
Dancing is Forbidden
26
Apr 27, 2003 06:11 PM
