SC61 compressor wheel???
Old Oct 30, 2003 | 01:10 PM
Justin Olson's Avatar
Default SC61 compressor wheel???
Does the SC61 use a Gt35r 82mm compressor wheel, or a gt40 82mm wheel?
Here are precisions specs on the turbo:
http://www.precisionte.com/sportcompact.php
Here are some GT series compressor maps:
http://www.atpturbo.com/root/index.htm
Thanks,
Justin
Old Oct 30, 2003 | 01:13 PM
b18bturbo's Avatar
Default Re: SC61 compressor wheel??? (olsonjus)
it uses the gt37 .76mm trim wheel
by the way here is all the info on it
Precision's line of T3/T4 turbos for Sport Compact vehicles comes standard with Precision's TA31 style exhaust housings with a 5-bolt discharge side in A/R's of .48 or .63. SC61 comes with the GT wheel with a 2.795" inducer and 2.437" exducer (76 trim).
Available with or without internal wastegate. Each turbo comes with a 360-degree race bearing center section and a T04E compressor cover with a 3-inch inlet and 2-inch outlet. Larger T04S cover with 4-inch inlet and 2.5-inch outlet available at an extra charge. SC61 has a 61mm compressor wheel that has a 2.416" inducer and 3.227" exducer (56 trim). Supports up to 680-hp at the flywheel with proper tuning.
Old Oct 30, 2003 | 08:46 PM
DIRep972's Avatar
Smarter than you
Default Re: SC61 compressor wheel??? (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo &raquo;</TD></TR><TR><TD CLASS="quote">it uses the gt37 .76mm trim wheel
SC61 has a 61mm compressor wheel that has a 2.416" inducer and 3.227" exducer (56 trim). </TD></TR></TABLE>
actually viren, it is a GT40 wheel, which is used in the GT35R. the exhaust wheel is 76 trim. the compressor is 56 trim. 2.4/3.2
Old Oct 30, 2003 | 09:40 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: SC61 compressor wheel??? (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">
actually viren, it is a GT40 wheel, which is used in the GT35R. the exhaust wheel is 76 trim. the compressor is 56 trim. 2.4/3.2</TD></TR></TABLE>
Direp is 100% correct. The specs on the GT37 are 2.25" in/ 3" ex. Me and direp looked deep into this a few months ago..hehe
art
Old Oct 30, 2003 | 09:45 PM
DIRep972's Avatar
Smarter than you
Default Re: SC61 compressor wheel??? (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">
art</TD></TR></TABLE>
its almost been a yr.
Old Oct 31, 2003 | 05:20 AM
b18bturbo's Avatar
thanks guys i thought it was the gt37 wheel
motoxxxman
Jun 9, 2017 06:25 PM
TurboTagTeam
Jun 3, 2008 09:39 PM
Stock@$$GSR
Apr 18, 2002 06:22 AM
