greddy kit won tspool until 4k
Old Nov 1, 2003 | 06:32 AM
untitled's Avatar
Default greddy kit won tspool until 4k
i am running off the wastegate right now and the damn thing wont spool till about 4k. thats only 5psi. there are no boost leaks. ive check. i noticed when i changed the iacv that there was little specs of aluminnum in the screen. could this be the turbo touching down and destroying itslef?
Old Nov 1, 2003 | 07:42 AM
MachAF's Avatar
Default Re: greddy kit won tspool until 4k (Vetter)
What do you mean your running off the wastegate?
do you mean there is no vaccum hose connected to the waste gate.
On my greddy kit I didn't get full boost till about 4k also, 7psi. It really didn't pull hard until 5k.
People on here tend to say they reach full boost at a lower RPM then they actually do.
Old Nov 1, 2003 | 12:02 PM
untitled's Avatar
Default Re: greddy kit won tspool until 4k (MachAF)
the wastegate is hooked up. i tested it out and left it unhooked and it will only boost to about 7-8.
Old Nov 1, 2003 | 02:42 PM
PHiZ's Avatar
your exhaust could be choking up your spool times, describe your setup...
-PHiZ
Old Nov 1, 2003 | 04:26 PM
untitled's Avatar
Default Re: greddy kit won tspool until 4k (PHiZ)
greddy kit
z6 motor
type 24 fmic (the smaller greddy one *i forgot*)
turbo xs rfl
stock greddy downpipe
2.5 test pipe
2.5 cat back
2.5 tanabe hyper medallion chambered muffler
Old Nov 1, 2003 | 05:22 PM
Sonny's Avatar
That stock Greddy downpipe is ridiculously small. Still, even my friend's car (2000 Civic Si) with 3" everything (including DP), it wasn't spooling till about 3800.
Sonny
Old Nov 2, 2003 | 09:59 AM
untitled's Avatar
Default Re: greddy kit won tspool until 4k (Sonny)
well i think i am buyin super 60 or what ever you call it.
.48 ar turbine
.63 ar compressor
60 trim
i think that should yiled some good numbers at 10 psi.
with zex cam and minor head p&p tuned with my zdyne gold i want to see 230whp.
Modified by Vetter at 1:57 PM 11/2/2003
Old Nov 2, 2003 | 10:35 AM
Sonny's Avatar
Those numbers don't make much sense. Is it the Super 60 or the 60-1? Those turbos are not even close to being the same. One is good for about 300whp. The other is good for about 600 whp.
Sonny
Old Nov 2, 2003 | 10:56 AM
untitled's Avatar
i though they were the same when i posted that. the super 60 is what i meant. go by my specs i have.
Old Nov 2, 2003 | 01:50 PM
PHiZ's Avatar
A turbo with a bigger housing, will actually spool HIGHER.... I'm not commenting specifically on those choices, but make sure you choose the size very carefully!
I have 3in exhaust now, I start to spool ~3k and hit full boost at 3.5K.
-PHiZ
Old Nov 3, 2003 | 07:19 PM
untitled's Avatar
fins are toucinh down and theres shaft play in the greddy 15g anyway. time to upgrade.
cdscivic
Oct 16, 2014 02:17 PM
I:_Drive
Honda Civic (2006 - 2015)
19
Jul 13, 2007 10:48 AM
b00sted4dr
May 22, 2005 11:53 AM
boostincoupe
Jan 24, 2005 02:31 AM
rice a roni
Jan 6, 2004 03:23 PM
